Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: Rear wheel curiousity NEW TOPIC NEW POLL POST REPLY
DB
posted April 14, 2008 10:12 AM
How much harder (or maybe it's easier) to remove a rear wheel on a shaft drive compared to a chain drive??
Dan
04 ZX10r (Track only)
08 Concours14
TedG
posted April 14, 2008 07:04 PM
Definetly easier. No chain to mess with.
Remove the one bolt holding the caliper hanger.
Remove the axle.
Drop the caliper.
Pull the wheel away and it falls out.
Replacing is easy.
Slide the axle in and hang the wheel on it.
Slide the wheel against the splines.
Put the caliper hanger back in place.
Bolt it back on;
Tighten the axle nut.
No fooling with the spacer on the chain side.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
DB
posted April 16, 2008 01:27 PM
Thanks Ted
Dan
08 Concours14
zeexman
posted April 27, 2008 02:00 PM
Does the center stand raise the bike enough to drop the tire or do you need a jack?
TedG
posted April 27, 2008 07:07 PM
The center stand is just fine. Just lean the wheel over and it comes right out. The whole job is much easier than a chain drive. less spacers, no adjustments.
Ted
The fast color!!
Green 2005 ZX10R
elcuby
Erick
posted July 19, 2009 03:44 PM
any video ? or pictures on the process...
elcuby
posted July 20, 2009 08:11 PM
I always like pictures, esp moving ones!
0.24545311927795 seconds processing time
