Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: Vertical headlight adjustment NEW TOPIC NEW POLL POST REPLY
c14rider
posted September 13, 2007 05:50 AM
Took the C14 out for its first night ride last night. Headlights are aimed WAY, WAY too low. Don't know if this was a setup prep item that was missed, or what. Question is, do I use the dash mounted adjustments to bring them all the way up, or is there a course adjustment I can do first and then use the dash controls to 'fine tune' them?
gpz1100
posted September 13, 2007 06:18 AM        Edited By: gpz1100 on 13 Sep 2007 07:18
I just adjusted mine a # of turns to bring it to where I thought the light was good.
Keep in mind, you turn the left adjuster counter clockwise, right clockwise (basically out from the center). I took probably close to 10 turns to get it where the light was far enough ahead.
wormgear
posted September 13, 2007 09:14 AM
yep, same with me and other folks here too. Just crank and crank some more, they'll come in.
GodDamnit there's always such a big temptation to be good, to be good! (Tom Waits)
fastestbusaaround
I eat Fish...
posted September 13, 2007 08:02 PM
C14Rider...you just need to use the dash-mounted adjusters and ignore what they say in the manual about using the high beams to adjust. I set them up using the low beams and they're perfect.
FYYFF!!!
tundra tom
posted September 14, 2007 05:29 AM
There's been some reports of those knobs falling off too. I put a dab of RTV Silcone on the shafts, so far so good. I'd avoid glue since they need to be removed to allow the dash to come off.
"When my time has come, I prefer to be in the Saddle rather than the Recliner"
0.44009399414062 seconds processing time
