Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: sealing the engine compartment? NEW TOPIC NEW POLL POST REPLY
posted August 16, 2007 04:31 AM
any thoughts on how to better seal the engine comparment so air only escapes through the two massive fairng side vents>?
In10city
posted August 16, 2007 04:48 AM
Here's your permanent solution:
TedG
posted August 16, 2007 01:05 PM
Ick!!!!!
posted August 16, 2007 07:43 PM
actually... I did think about using that... I've considered stuffing a garbage bag or some other plastic bag in the gap between the fairing and the engine and then filling the bag with the expanding foam... they actually make a low expansion version because the one in the pic would blow the fairing apart.
TedG
posted August 17, 2007 12:32 PM
I am going to use the gray weather stripping from Home Depot, it has sticky on one side and I can use it to build up the existing foam by sticking it to the foam and shaping the weather stripping with an air grinder.
marklawrence
posted August 19, 2007 10:04 AM
I used to make a kit for the FJR. I used standard foam, cut into sections about 1" x 2" x 6", attached to the inside of the fairing with double stick tape. It worked pretty well. It's important to get good tape - I used some industrial 3M outdoor tape.
http://www.calsci.com
0.25715708732605 seconds processing time
