Ducati Superbike Discussion Forum
BIKELAND > FORUMS > DESMOSUPERBIKES.com > Thread: OK! Just got the 1098 back from the dealer... NEW TOPIC NEW POLL POST REPLY
deathpulse
posted August 01, 2007 10:16 PM
I had about 800 miles on her. For those that don't know, my bike has always been a bit sketchy below 4K RPMS, its idle was screwed up (1750 to 2200 RPM), AND it ran richer than Bill Gates. I brought it up to Portland Ducati (Moto Corsa) and they did the following:
1. Replaced ECU. Mine was the ECU that came with my Termi's (not the original ECU). This was overnighted out and returned a day or 2 later. Apparently, even though it was a Termi ECU, it was an older one and was replaced.
2. did some timing fixing??
3. fixed the mixture (maybe part of the ECU?)
4. fixed the idle
WHAT A DIFFERENCE THIS MADE. The bike runs MUUUUCH Better all across the rev range. It not idles between 1250 and 1400 (1400 if cold)... right in where it should and its SOOO much smoother and more responsive. No stalls at all and not rich AT all. I STRONGLY recommend you bring your bikes back to the dealer if you have the conditions I mentioned above. Keep in mind, I NEVER had the stall problem...
OK - off to ride more!!
posted August 02, 2007 06:50 AM
Good deal!
posted August 02, 2007 06:53 AM
wow... great to hear it works! Fortunately mine's run pretty much perfectly since new...
posted August 03, 2007 06:43 AM        Edited By: swft on 3 Aug 2007 07:57
Didn't you post about it stalling?
http://www.bikeland.org/board/viewthread.php?FID=32&TID=31316&set_time=1180646578
deathpulse
posted August 08, 2007 12:22 AM
hey swft - I posted that my bike doesn't stall but had high idle/rich etc (its in that post that you err.. posted)
0.35898494720459 seconds processing time
