Suzuki GSXR1000 / Gixxer 1K
BIKELAND > FORUMS > GSXR1000 ZONE.com > Thread: 05 gsxr1000 problem NEW TOPIC NEW POLL POST REPLY
biggmoinc
posted June 09, 2012 04:06 AM
05 gsxr1000 problem
05 1000, bike ran perfect prior to engine removal, got engine head n cam package from npsracing done, put engine in, started it for heat cycles, didn't go over 4k, bike only got to 160 temp before I shut it off, exhaust was glowing red, spark plugs look fine, actually didn't even look like they got wet (fuel ) bike runs like its starving for fuel, like the older gsxr when running low on fuel before u turn to reserve, took pump n fuel rail and injectors out, cleaned them all out, bike still runs boggy, like its not on all cylinders, there's 2 plugs under tank, 1 white 3 wire n a 2 wire clear plug that aren't hooked up, I font believe they were hooked up from the beginning, any ideas, oh, n removed 2ndaries plates prior to install, could removing them cause this?
biggmo@aol.com
biggmoinc
posted June 11, 2012 03:04 PM
Installed secondaries, wasn't the issue, any ideas?????? Could it b cams? Rook a tank and throttle bodies off a running bike and bike still runs the same
biggmo@aol.com
morris
posted February 07, 2015 02:18 AM
this is very nice post
0.21861100196838 seconds processing time
