BIKELAND > FORUMS > CLASSIFIEDS > Thread: F/S: complete dry nitrous kit NEW TOPIC POST REPLY
Hibs
posted October 17, 2013 04:14 AM        Edited By: Hibs on 17 Oct 2013 12:16
This is a kit I have pieced together, but it has everything you would need, plus bunch of extras. What is included.... 3 dynotune nitrous solenoids, 3 stainless steel AN lines (two short/one long), poly line with proper fittings, 3 relays, a WOT activation switch with bracket, two master arm switches, a poly line 1-2 junction, two 90* nozzles, three jets from Dynotune for 20-30-40hp plus an extra jet in the solenoid currently that was supposed to have been 55hp, two nitrous bottles (blue 2lb NOS and silver 2.5lb *not sure on brand* that I installed a siphon tube and new valve in), liquid filled TNT nitrous gauge, all the fittings you need plus some extras.
The way I was going to run this kit: bottle mounted in rear, long AN line from bottle to the solenoid up under the tank, poly line from solenoid to the 1 into 2 junction, then poly line to the two nozzles-each one in the ram air tubes. With the dynotune solenoids the jets are in the solenoid, so one jet is all you need. With the nozzles in the ram air tube it helps mix with the incoming air better before it reaches the air box, a proven method. My only suggestion would be a RPM operated window switch for safety, but it is not required.
I would need to get $275/shipped.
And since everyone likes pictures...
Hibs
posted October 17, 2013 08:01 PM
I found something else I really want to buy... $225/shipped for a limited time!
Hibs
posted October 20, 2013 12:06 PM
ok ok... $210 shipped, to get this thing out of here!
Hibs
posted November 08, 2013 05:15 PM
make offer!
zx14durham
4n21
posted November 14, 2013 12:04 PM
Only see the bottle pics, Send pics to csmith046@nc.rr.com so I can see everything.
Hibs
posted November 15, 2013 12:21 PM
Sorry, everything has been sold. I failed to take this ad down.
0.21886086463928 seconds processing time
