BIKELAND > FORUMS > CLASSIFIEDS > Thread: zx12r drag bike for sale NEW TOPIC POST REPLY
almost_les
posted September 07, 2012 06:44 PM
ace performance stage 2 porting
cp 13.5:1 pistons
degreed cams
inconel exhaust valves
pair block off
r&d undercut transmission w/hd clips and nitrous cut
12 over arm
EK ZVX o-ring chain
Shinko hookup
brocks sidewinder
power commander 5
wideband 2 with autotune
lcd-200 w/ 1gig datalogging
reflashed ecu with raised rev limit and nitrous map
shortened forks
spraybar
2 stage nitrous w/purge
nox box 2 nitrous controller
2 2.5lb bottles
custom rear suspension
455cc denso injectors
cut tank
6 over tail
bear racing velocity stacks
heavy duty valve springs
titanium retainers
airshifter
high pressure air system with reservoir tank and low pressure backup
mps switch swapper
blue indiglo dials
arc2 cdi with 2 step
hays convertible clutch with billet basket and mtc spacer
heavy duty shift shafts
drag step seat
gss242 fuel pump
real world mapping
heavy duty studs
muzzys aluminum fans
adams oil pan
cr10e spark plugs
title in hand
6 grand/ best offer
runs 9.5's in 7000 feet of air with a light rider, 9.7's with 185lb rider. no idea what it will do on spray yet, or when ran at a decent altitude
here it is with my 185lb antijocky: smooth as silk. 4th pass ever on this bike. only drag experience he has is running 13's on his warrior. makes rookies look good.
http://www.youtube.com/watch?v=W_yJ92iSqrQ
0.25208592414856 seconds processing time
