BIKELAND > FORUMS > CLASSIFIEDS > Thread: FS: 2003 ZX12 + All leftover parts!!! NEW TOPIC POST REPLY
avb5983
posted June 28, 2012 03:12 PM
For Sale:
2003 ZX12R $5,500obo
W/ Approx 7K on clock (actual)
Muzzy Oval Can w/ Wrapped SS Akra Header and mid-pipe
PowerCommander USB w/ HUB and map selector switch
Soupy's fully adjustable Lowering links
Speedo Healer
17/48 gearing
Custom Paint Job w/ Monster Energy Theme. Monster symbols under Clear
Gloss Black Painted Frame
Powercoared Swingarm w/ built in airbox for air shifter
MPS Airshifter w/ Fuel Kill Onboard Compressor
Mirror Blockoffs
Custom wrapped seat.Drivers seat has some material shaved out to put ride lower.
Will get Seat w/ Cowl and Monster energy
Undertail
LED Taillight
Custom Green LED "Night Rider" driving light
Deka Battery always on Battery Maintainer
Also, lots of left over parts. No reasonable offer refused!!!
Make Offer:
Powercommander IIIr w/ serial-2-usb adapter
Zx12 Head - Bought off here, but never installed. Head has mild port job. Aftermarket valves and springs. No paperwork. Has APE adjustable cam sprockets
Muzzy Drilled Clutch Hub w/ HD Springs
WEGO III - Still on Bike but will take off if interest
Muzzys Blue Velocity Stacks - Still on Bike but will take off if interested
Buell Pegs Modified to fit ZX12 -
OEM Rectifier -
MISC Relays
Muzzy Bottle Bracket - Mounts under the seat.
Stock Throttle Bodies w/ Injectors and injector Harness.
Stock Stem and Triple Tree - Triple tree has some flaws
Stock Shock Spring
Stock Mirrors off 2003 - Some rash, but good condition.
Stock Knuckle -
Stock Front Brakes
Stock Kickstand w/ switch
Stock Front Sprocket - had less than 5k on it when i took it off
MPS Air shifter Pressure Switch
Stock Fuse Box
Stock Fans
Stock Shock w/ Spring
C02 Pressure regulator w/ MPS bottle adapter
Manual Cam Chain tensioner
Stock rear sprocket w/ hub
Stock rear sprocket
Stock rear brake - Chromed once but will need redone
Stock rear Brake Master Cylinder w/ reservoir
Vortex 47 tooth rear sprocket
a lot more. Who knew you could accumulate soo much stuff in 4yrs???
All HighRes Pictures are here.
4Sale pictures by avb5983 - Photobucket
**More Pics of bike to come later!!!
email: antoniobaker@gmail.com
0.29491305351257 seconds processing time
