BIKELAND > FORUMS > CLASSIFIEDS > Thread: zx14 everything performance NEW TOPIC POST REPLY
Compton
posted February 03, 2012 03:19 PM        Edited By: Compton on 3 Feb 2012 23:29
06/07 parts all used, in great shape. zero street miles
Power Commander + Hub + Ignition Module = 350.00
Schnitz PNC-3000 nitrous controller = 375.00
Muzzys Bonneville pro 125.00
NOS Mini 2 stage progressive controller 175.00
Modified Adams Spray Bar with 8 nozzles for 2 stages, anodized black + NX solenoid, adams solenoid, braided and soft lines, with 16 and 25 jets. good for 150hp 350.00
zx14 cut seat by adams = 125.00
zx14 cut seat by tobin, more of a riding seat = 160.00
zx14 catalyst race seat, bad shape, been repaired 60.00
Zx14 no name ebay fiberglass race seat 50.00
Adams / Litz Shock re-valved and shortern with new spring for 65" 180lb rider 300.00
Adams Straight link powder coated black 140.00
Smoked Taillight by me with Smoked turn signals by Clear Alternatives 60.00
Custom Co2 / air shifter . Mr Turbo under rear set bracket, shorter ram, braided lines, carolina cycle high pressure regulator, solenoid, fits a small 3.5oz bottle in trunk. 275.00
Brocks Performance TiWinder BLUE - 1200.00
Brocks / BST wheels 16" front 17" rear. sprockets, galfer rear rotor, yana shinki front rotors, tires included 3300.00
2x4 1510cc motor. Marine Crank 4+, carrillo rods, Adams/JE pistons, fast by gast trans, brocks shift shafts, adams case mods, Comp CNC oil gear, muzzys oil plate, new bearings, adams 1.5" pan anodized black, 4000.00 = fresh, only has break in / heat cycles
Zx14 cylinder head, ported with Biggest WEB cams you can fit in the stock buckets 1500.00
48mm Throttle Bodies 300.00
Complete Fuel System one off custom, 08 housing, walbro internal pump, all -6 braided lines, aeromotive regulator, and my billet rail. quiet, and flows good. 400.00
keyset 100.00
Gauges one cluster with 13xx miles 300.00 and another with 36xx miles 280.00
07 Candy Plasma Blue body, great shape with also a 08 zx10r front fender and brackets 850.00
Rock Solid Manufacturing Kawasaki ZX14 GSSF Series Clutch, brand new 1600.00
adams swing arm, very clean with black anodized axle adjusters and bottle holder, 64-68" 750.00
billet quick access clutch cover, black and machine by adams. just like the one on there prostreet bike 400.00
I have more, but those are the big things for now. I'm in chicago. paypal please add 3%
b.w.
joseph702
posted February 03, 2012 03:32 PM
hey can u call me ? 207-217-0525 joe
cas15
posted February 03, 2012 04:06 PM
Could u send pictures of the adam swing arm to dannycastro49@yahoo.com and does the swing arm take air
  Ignore this member    Click here to visit cas15's homepage.
oldkawboy
posted February 03, 2012 06:45 PM
PM sent.
Thanks,
Dan
codyc_13
posted February 04, 2012 07:30 PM
I will take the Adams cut seat, messages you on psychobike also
8.97 at 149mph
rspauldi
posted February 04, 2012 10:17 PM
I am interested in the wheels without the extras. would like to get the price down a bit so i can afford the rims by them selves. I am a bit concerned with the 16" front rim and how it marry's with the 17" rear wheel though. can you please explain why you decided to use the 16" rim instead on the front instead of the 17" rim?
my name is rick and I am a serious buyer 12143154370.. pls call or txt
rspauldi
posted February 04, 2012 10:22 PM
also interested in the tinted braked and blinker lens' and the ZX10 fender brackets as well.
thanks rick 214-3154370
oldkawboy
posted February 05, 2012 10:16 AM
New PM sent.
Thanks,
Dan
Compton
posted February 05, 2012 01:19 PM
TB and Billet Stacks Spoken for, awaiting payment
Adams Seat awaiting Payment
NOS min 2 awaiting payment
SOLD
RSM clutch
Billet clutch cover
PNC 3000
Also have
Litz / Adams revalve stock length 175.00 64" 190lb rider.
GPR V1 blue with mount zx14 steering stabilizer. 325.00
Innovate DL-32 data logger 375.00
Tiger Racing 2 Gauge Holder powder coated black 15.00
Adjustable lowered kickstand, cut and trimmed down for a real low bike. powdercoated black 50.00
throttle bodies, stock all taken apart. use for cores for boring. not 100% sure i have all the parts, but they are ready to be bored, swap all of your parts. 50.00
Stock subframe with a tiger undertail, all powder coated semi gloss black 150.00 will not separate.
black coated black mirror block offs 10.00
Real Vortex gas cap and base, black 45.00
internally Lowered Forks,black anodized tubes, lower legs powder coated semi gloss black, straight never wrecked. 200.00
2 starters 40 ea
4 coils 15 ea or 45 for all.
zx14 RECTIFIER/REGULATOR 50.00
rear passenger pegs, powder coated semi gloss black with billet pugs filling the exhaust holes 40.00
stock rear sets powder coated semi gloss black 40.00
anything else factory wise, just ask. I may have it.
b.w.
Compton
posted February 05, 2012 02:19 PM
Tiger gauge holder sold.
b.w.
Compton
posted February 06, 2012 04:14 AM
Sold awaiting payment on the stock length Adams / Litz revalve.
Also have a very clean hardly used BMC race filter. $25.00
Front fairing stay with mirror bracket, oem 55.00
06/07 ECU / Relay Box 150.00
08+ aluminum air filter door cover 10.00
Brake Calipers, fronts and rears with good life on the double HH pads. all have been powder coated semi gloss black. 150.00
Spiegler - Braided Brake Lines, Black lines with Blue Ends and Blue Bolts. 3 lines up front and a longer rear line for up to a 12" over arm. 165.00
OEM headlights, pair. great shape! 150.00
b.w.
Compton
posted February 06, 2012 05:42 AM
BMC race sold, awaiting payment.
I'm going to start digging through more part bins, i'm tired of being a hoarder.
b.w.
Compton
posted February 06, 2012 07:34 AM
Adams Seat and and Stock Length Litz / Adams revalve SOLD.
b.w.
Compton
posted February 06, 2012 08:12 AM
Two wheel werkz zx14 tank pivot. 55.00
b.w.
SPIKE
posted February 06, 2012 12:29 PM
keyset 100.00
mrking
SPIKE
posted February 06, 2012 12:30 PM        Edited By: SPIKE on 6 Feb 2012 20:32
hey compton could you give me a call 316-312-0655 greg
mrking
Compton
posted February 07, 2012 06:14 AM
deal pending on the tiwinder, power commander, hub, ignition module, tobin seat, forks.
ttt.
b.w.
Compton
posted February 07, 2012 06:27 AM
Also have a super clean low mile radiator/hoses with a schnitz high pressure cap, extra fan, and a muzzys fan anodized black in the stock housing. 270.00
b.w.
joseph702
posted February 08, 2012 07:42 PM
tiwinder sell?
Compton
posted February 09, 2012 03:39 AM
TiWinder is still for sale
b.w.
Compton
posted February 09, 2012 06:52 PM
mirror block offs sold, thanks!
b.w.
Compton
posted February 10, 2012 05:39 AM
Shifter and NOS MINI sold. thanks.
now who wants the BSTs, Motor, and swing arm?
Engine Is all together and running. All together price of 4800.00, included a 06/07 CLutch basket, 4 passes on a fresh clutch pack with "real street" clutch setup. Would cost over 9k to duplicate this setup with good cores
b.w.
Compton
posted February 11, 2012 11:22 AM
Fuel System SOLD. thanks!
b.w.
codyc_13
posted February 11, 2012 11:33 AM
Got the cut seat and litz shock yesterday, everything as described!!! These cut seats are SWEET!!! thanks.
8.97 at 149mph
Compton
posted February 11, 2012 12:19 PM
thanks again! enjoy
b.w.
All times are America/Va [ This thread is 4 pages long: 1  2  3  4     Next» ] < Previous Thread     Next Thread >
0.27732300758362 seconds processing time
