BIKELAND > FORUMS > CLASSIFIEDS > Thread: 06 ZX14 Part out Everything must go!!!! NEW TOPIC POST REPLY
thutch26
thutch26
posted October 17, 2011 01:30 PM        Edited By: thutch26 on 17 Oct 2011 21:31
I hate to do it but my finances have finally caught up with me... I've been on dissability since March and havent gotten benefits since June... so I got to put my priorities first...
all prices are plus shipping and paypal fees unless noted!!!!
Chip Hunter Assembled 06 ZX14 Engine
Adams Ported head
RnD trans
Brock's Billet tranny shafts
Carillo stock length H beam rods
Je 2mm nitrous pistons
Brand new lightened and balanced crank with fluted journals done by Marine
Stock degreed cams
Crank balancers removed using osr delete shafts
rpm high pressure oil valve
muzzy billet oil pump cover
Brand New rod and crank bearings
Adams billet 2" oil pan
Naarden pair valve block off
APE Heavy Duty head studs
APE valve springs with titanium retainers
4500.00 or 4000.00 without adams pan
___________________________________________________
Bst's Wheels "stock sizes" with Black 44t Vortex Cat5 sprocket no tires or rotors 2850.00
Cycle Logic single stage lockup 250.00
MrGsx1300r nos spraybar kit with lines and showerhead ,zex lighted purge with solenoid, Adams nos solenoid, gauge, stainless braided lines from bottle to showerhead, microswitch everything but a controller 350.00
Walbro 255lph in tank fuel pump with crushed regulator done by Garron @ Adams perf. sold....
2006 injectors recently cleaned and flow tested 75.00 sold.....
Adams Strong arm 64"-68" wheelbase it has a small crack in a few of the letters in the chainguard.. no biggie 750.00
Stock throttle bodies no injectors 125.00
Litz revalved shock set up for 170-190lb rider at 65"-70" 225.00
Adams straight link 120.00
Gafler wave rotors 1 front and 1 rear 250.00
ZX10 front fender conversion Gloss Black 150.00
Blue Anodized Brock's Tiwinder "sold" pending payment
pc3r 150.00
multi function hub with switch and/or relay for automatic map switch 75.00
dynojet wideband commander 250.00
boost by smith led shiftlight with optional autoshift 50.00 sold
Complete airshifter kit with compressor, lines, muzzy digikill 3
mr. turbo under peg airshifter mount. no tank 400.00
Complete body kit...12" over catalyst tail, tank with chrome keyless gascap, all plastic has just been recently painted gloss black.. no lowers 1200.00
Osr Catalyst tail brace 125.00
Brock's front billet strap brackets and strap 125.00
Stainless front and rear brake lines 75.00
GPR steering stabilizer 300.00
radiator with 2 fans 175.00
pmr dual handlbar switch 50.00
pmr handlebar killswitch w/lanyard 50.0
1/5th turn throttle cam 25.00
schnitz 2 dial nos controller 175.00
schnitz efir ignition retard unit 250.00
shorty levers 50.00
clear alt. tinted/smoked led tailight and front and rear turn signals 150.00
3 2.5lb Nos bottles 2 blue and 1 raw aluminum finish 100.00 each or 270.00 for all 3
Adams Billet threaded lowering links 125.00
Adams Straightlink a little scuffed up but perfectly useable! 125.00
2006 Ecu and Relay Box 250.00
Complete Wiring harness from 06 zx14 125.00
Gauge cluster with 3800mi "perfect" 400.00
Headlights "perfect" 215.00
zx14 engraved polished mirror blockoffs 50.00
complete front end, forks,trees, everything but left and right bars/controls, and calipers.. 250.00
1 left front brake caliper 60.00
left and or right complete controls, stock levers, reservoirs,switches, lines, ready to bolt on 150.00 /75.00each
Stock Subframe 75.00
left and right rearsets with shift lever, brake master cylinder, brake lever, 225.00
rear brake caliper 55.00
Bazzaz Z-fi AFM tuner unit with no sensor "new" 75.00
I'll be listing more stuff as i start to take it apart...
I can get you pics of all parts. just lmk feel free to call with any questions 217-766-4554 Todd
shoot me some offers on the stuff... least i can say is no
thutch26
thutch26
posted October 17, 2011 06:08 PM
fuel pump
injectors
shift light
frnt fender and brackets
osr seat brace
throttle cam
pc3r
efir
shock
soldsoldsold!!!!!!!!!!!!!!!!!!!
TH1RT3EN
Trial And Error Control
posted October 17, 2011 06:17 PM
PM sent about levers...
Patrick
thutch26
thutch26
posted October 17, 2011 06:42 PM
Patrick
replied
bradkong12
posted October 18, 2011 05:26 AM
sry to hear about ur bad luck, keep ur head up
bradkong12
thutch26
thutch26
posted October 18, 2011 05:32 AM
Thanks!
I'll be ok.. when my lawyer gets thru with them I'll come back out swingin!
TH1RT3EN
posted October 18, 2011 06:47 AM
Payment sent for levers,
Thanks!!
Patrick
thutch26
thutch26
posted October 18, 2011 05:59 PM
shorty levers sold
Cycle Logic single stage lockup sold
Headlights "perfect" sold
schnitz efir ignition retard unit sold
Osr Catalyst tail brace sold
1/5th turn throttle cam sold
boost by smith led shiftlight with optional autoshift sold
pc3r sold
ZX10 front fender conversion Gloss Black sold
Litz revalved shock set up for 170-190lb rider at 65"-70" sold
2006 injectors recently cleaned and flow tested sold
Blue Anodized Brock's Tiwinder sold
Adams Straightlink a little scuffed up but perfectly useable! sold
ZX12Boricua
posted October 19, 2011 01:38 AM
$250 for the GPR steering damper?
Let me know.
2012 ZX14R Blue Current
2007 ZX14 Black Sold
2006 ZX10R Yellow Sold
2002 ZX7R Silver,Black,Yellow Stolen
2000 ZX12R Red Sold
1989 GPZ900R Red Sold
thutch26
thutch26
posted October 19, 2011 06:38 AM
Let me know.
Pm sent
ZX12Boricua
posted October 20, 2011 01:08 AM
Check your PM and let me know.
2000 ZX12R Red Sold
thutch26
thutch26
posted October 20, 2011 10:16 PM
replied
NINJA12
posted October 21, 2011 07:57 AM
bazzaz still for sale?
thutch26
thutch26
posted October 21, 2011 03:39 PM
Yes bazzaz is still available
NINJA12
posted October 21, 2011 05:48 PM
i'll take it.,
call me back.
901 number
thutch26
thutch26
posted October 22, 2011 03:20 PM
pm'd ya... lmk
veronicamays
posted October 22, 2011 06:22 PM
Is the steering damper still available
thutch26
thutch26
posted October 23, 2011 04:18 AM
I'm waiting on a reply from zx12boricua... lmk
ZX12Boricua
posted October 24, 2011 02:31 AM
I pass.
Thank you.
2000 ZX12R Red Sold
thutch26
thutch26
posted October 24, 2011 06:26 AM
Stabilizer is still available... lmk
zixxer14
Damn that was Quick
posted October 24, 2011 10:50 AM
Sent PM.
Newf14
2007 ZX1400
posted October 24, 2011 03:35 PM
Like a price shipped on the multi function hub shipped.Thanks.
Newf14
thutch26
thutch26
posted October 24, 2011 04:57 PM
dampner ... sold
oil pan... sold
bazzaz....... sold
left caliper and master cylinder.... sold
thutch26
thutch26
posted October 26, 2011 03:04 PM
1 left front brake caliper sold
pmr dual handlbar switch sold
GPR steering stabilizer sold
pmr handlebar killswitch w/lanyard sold
shorty levers sold
pc3r sold
Adams pan..... sold
Bazzaz Z-fi AFM tuner unit with no sensor sold
Newf14
2007 ZX1400
posted October 26, 2011 03:37 PM
P.M Sent
Newf14
0.24782395362854 seconds processing time
