BIKELAND > FORUMS > CLASSIFIEDS > Thread: - Fresh Competition CNC Ported ZX-14 Head - NEW TOPIC POST REPLY
posted August 17, 2011 06:23 AM        Edited By: Shane661 on 17 Aug 2011 14:28
This head has never been installed.
I sent out a spare cylinder head for some work. Jim at Competiton CNC provided the services:
This head was configured to get the most out of an otherwise stock engine. The mods are as follows:
1) High flow valve job with wider "nitrous cut" on the exhaust seat
A good valve job definitely will free up some hp. The seats are cut sligtly wider on the exhaust side of my setup, to allow for better heat dissipation while spraying nitrous.
2) Stage 2 CNC Port
The Stage 2 port will give up a little power down low, but make it up on top. However, with the increased compression due to the milling, I really won't be losing anything down low compared to the standard head.
3) .030 Flat Mill
There are a variety of milling options. My mill falls about in the middle. I will still get a significant gain in compression (should be around 13:1), but it is not quite as radical as the angle mill that they do for Supersport bikes. This also gives me a little room to resurface later, should the need arise.
4) Matched intake boots
Intake boots are hand-matched to the head, for optimum flow.
5) Shimmed Stock Springs
Jim also took the time to shim my stock valve springs for a little more pressure on the seat. Again, this setup is designed for stock cams. With stock cams you don't really need the huge seat pressures, and it will cost you some hp and also wear parts out more quickly.
New valve seals also installed.
$1000+SH outright. You can keep/sell your stock head. Install your cams and adjustable sprockets. PM me or email Shane at warp12racing dot com.
LeonidasZX14
posted August 17, 2011 04:37 PM
Awesome deal....
09' ZX14
jlewis02
posted August 17, 2011 04:48 PM
Wish I had the money right now.
08 ZX14
1.57 60'
6.09@124
9.24@155
SWB 5400ft DA 50hp shot
posted August 18, 2011 06:34 AM
I just talked to Jim and he said this head should make more than their Supersport head, and that setup has made 210hp on MR12. All dyno's are different, but this head should really perform on a stock motor.
oldkawboy
posted August 18, 2011 01:33 PM
That is a DEAL!!!!!!!
In case someone doesn't know Shane, he can be trusted & is a great seller.
Dan
01smokes
posted August 18, 2011 02:45 PM
damn good deal . i just sold one of my stock heads in a day for 325 guys, so just putting that out there what you would be paying for this head if you sell your head.
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted August 20, 2011 01:49 PM
SOLD
gilberjj
Friend of Fast
posted August 25, 2011 10:54 AM
SOLD
Dang...... it's just as well that this sold already.... i would have been very tempted and I just need to finish my bike.....
0.29144597053528 seconds processing time
