BIKELAND > FORUMS > CLASSIFIEDS > Thread: Built 2006 ZX14 motor 4sale NEW TOPIC POST REPLY
thutch26
thutch26
posted August 13, 2011 08:30 AM        Edited By: thutch26 on 13 Aug 2011 16:31
I'm not lookin for another motor plus cash...just need the $$$ I've been on dissability since March with little to no benefits so its gotta go... The rest of the bike will be parted if the motor goes first....
2006 zx14 cases bored and plated by Millenium
Adams Ported head w/ APE springs and titanium retainers
RnD backcut transmission
Brock's Billet tranny shafts
Carillo stock length H beam rods
Je 2mm nitrous pistons
Brand new lightened and balanced crank with fluted journals done by Marine
Stock degreed cams
Crank balancers removed using osr delete shafts
rpm high pressure oil relief valve
Muzzy billet oil pump cover
New rod and crank bearings
Naarden pair valve block off plates
APE Heavy Duty head studs
Modified ZX12 camchain tensioner
Stock clutch setup with heavy springs and spacers
motor assembled by Chip Hunter
I have several pc3 maps to get you started if need be!
motor has about 15 passes on it with about 8-10 being nos passes "60 shot"
4200.00 with stock oil pan
4800.00 with Adams Billet pan
I will consider partial trades.. lmk
dogg24
posted August 13, 2011 09:37 AM
Sorry about your luck, hope you get back on your feet soon and back to work so you can get back out there!!
2012 ZX14R SE, Streetmeg, PCV
AcadianaZX
Advertiser
posted August 15, 2011 04:01 AM
I want it if its not gone by the time I get back home in a few day form overseas. I should be back in the US on the 19th. Where are you located? I live in Louisiana.
James
thutch26
thutch26
posted August 15, 2011 06:47 AM
thanks dogg24
its cool.. i am 2.5hrs directly south of chicago... zip is 61846.... lmk
thutch26
thutch26
posted August 17, 2011 09:50 PM
ttt
AcadianaZX
Advertiser
posted August 19, 2011 04:39 PM
ttt
Sorry, I hate to back out on you. I wish I was able to come home but no one wants to come to work in Africa to relieve me on the boat. No time for drag racing for now. For getting your hopes up I'd like to send you something while your laid up if you'll let us help. Give Tressie a yell @ touchetj@msn.com.
James
Rideharder
posted August 20, 2011 09:17 PM
What is the HP?
  Ignore this member    Click here to visit Rideharder's homepage.
thutch26
thutch26
posted August 22, 2011 07:07 AM
I've never Dyno'd this particular motor but the last one I had was identical except it had stock rods and it made right at 200 on pump.
Big Whyte
posted August 27, 2011 08:57 PM
How can I get ahold of you?
Chris
806.886.8359
thutch26
thutch26
posted August 28, 2011 08:59 AM
217-766-4554
thutch26
thutch26
posted September 26, 2011 07:08 AM
still up 4 sale!!!!!!!! bike went 8.23 this past weekend!!!!!!!!!!!
0.21516108512878 seconds processing time
