BIKELAND > FORUMS > CLASSIFIEDS > Thread: Libertek LED Undertail Lights FS: NEW TOPIC POST REPLY
ZXLNT
posted February 10, 2011 07:30 PM
I will probably never get around to buying and undertail for my bike so I am selling my Libertek led undertail lights. These are simply THE BEST led lights you can buy for an aftermarket undertail. Nothing compares. These are literaly blindingly bright. Easily visible in daylight and simply dazzling at nightime. Retail when they were available was 200.00.
I will take a 100.00 for these as I dont believe libertek is in business anymore and you can't get these anymore. Simple 3 wire hookup. Ground, tailight, brakelight, and thats it. Two hole mounting system..
100.00 plus shipping in the CONUS which should be around 5.00 or so..
Tailight on.
Brakelight on
Hard to get a really good picture because they are so bright..
ZXLNT@Cox.net
Christoper
Christoper
posted April 19, 2012 01:21 AM
Does any one knows why are my undertail LED's solid all the time smd-5050?
I installed a hotbodies undertail for my yamaha 12 volt led lights 2003 r6. The turn lights were blinking fast. I corrected it flexible led strip by using a new relay. But for some reason the turn signals of the undertail are solid all the time. I switched back to the factory lights and they work fine. Any help!
ZXLNT
posted April 19, 2012 04:09 AM
The LEDS draw much less current and that doesnt allow the stock flasher relay to work correctly..
TH1RT3EN
Trial And Error Control
posted April 19, 2012 05:11 AM
use a resistor inline and it will eliminate the constant on situation.
ZXLNT
posted April 19, 2012 10:25 AM
Don't install the resistor "INLINE" that will only make the problem worse. You need to install the resistor in parallel with the blinker wire, from postive to negative, not in series/inline...
VitoAdjei
VitoAdjei
posted September 03, 2012 06:28 PM
Does anyone know of a good resource for where to place the LED's?
VitoAdjei
VitoAdjei
posted September 04, 2012 05:37 PM
_____________________________
fluorescent led bulbs
led ceiling lights
led strip lighting
0.24189496040344 seconds processing time
