BIKELAND > FORUMS > CLASSIFIEDS > Thread: 46mm throttle bodies NEW TOPIC POST REPLY
wrongway
posted January 29, 2011 06:54 AM
I am putting on 48mm throttle bodies on my 1530 .
these are the throttle bodies I bored to 46mm ,using zx12 throttle blades. secondary shaft was milled down for better flow.
$400 + shipping
Roy
madnessracing
Vmax and Busa Beater
posted January 29, 2011 10:39 AM
Any pics? does it come with sensors and are they calibrated? thanks
Shorty's Performance
Team Madness Racing
wrongway
posted January 29, 2011 09:05 PM
It has all the sensors and is calibrated. It has been running on my bike for a couple of years . it will have 440 cc injectors
I can get some pics when I swap out with the 48 mm bodies.
Roy
jetskidave
posted January 30, 2011 11:11 AM
Are these throttle bodies ready to bolt on and go?
Do they need Dyno time?
Dave
2014 ZX14R Flat Black
Akrapovic 4 into 1 exhaust CNC Performance high performance street motor stock bore 14 to 1 CP pistons
CNC ported head, Cams, 48mm Bored throttle bodies, complete blueprinted engine,
10 Over Adams arm, GPR stabilizer, air shifter, quickshifter Guhl reflash ECU with duel maps installed in the ECU.
243hp, 302 hp on Nitrous progessive controller. BST carbon rims
  Ignore this member    Click here to visit jetskidave's homepage.
06redzx14
posted January 30, 2011 12:47 PM
how long before they are off? send pics to ni2k6klub at hotmail dot com
wrongway
posted January 30, 2011 03:06 PM
Dave
they will be ready to bolt on . I am going to replace the 660 cc injectors currently in there with the stock '06 440cc injectors. I can pull them off tomorrow if someone definitely wants them.
you may need a custom map since the volume a part throttle will be more than stock... you may be OK with a flies out map since most of them are on the rich side anyway. I think I would be on the safe side any either datalog or get a custom map.
Roy
KAWABUSAKID
Fast as my $$ will take me
posted January 30, 2011 04:48 PM        Edited By: KAWABUSAKID on 31 Jan 2011 00:50
noticable difference over stock?
  Ignore this member    Click here to visit KAWABUSAKID's homepage.
wrongway
posted January 30, 2011 05:11 PM
not without port work
Roy
06redzx14
posted February 08, 2011 02:54 PM
Any pics yet Roy?
wrongway
posted February 08, 2011 03:06 PM
Any pics yet Roy?
I will finish the 48mm throttle bodies tonight , so I should have the 46's off tonight or tomorrow.
Roy
wrongway
posted February 10, 2011 10:00 PM
Sold ....
0.32093501091003 seconds processing time
