BIKELAND > FORUMS > CLASSIFIEDS > Thread: Cleaning out the garage.... NEW TOPIC POST REPLY
TH1RT3EN
Trial And Error Control
posted January 13, 2011 05:04 PM        Edited By: TH1RT3EN on 14 Jan 2011 01:07
The following are Roaring Toyz products.
I have a Set of Spiked Bar Ends. One of the spikes is scratched on the very tip of the spike. Other than that they are in excellent shape. $25.00
I have a set of Fork Covers with "ZX" engraved in them, Excellent shape $30.00
I have an Oil fill cap with "ZX" engraved in it, Excellent shape $20.00
I have a set of Swing arm Pivot caps to cover the ugly holes in the frame of the ZX14. One cap has a small scratch on it. Comes with the threaded rod that holds them in place. $30.00
I have a Clear Alternatives Green Integrated tail light for the ZX14. Brand new still in box never been out of the plastic. $65.00
I have a Candy Lime Green ZX14 front fender. Fender has a small crack in the front lip (barely noticeable) and a spot of road rash on the right front corner. Can be fixed and painted if you want. $50.00
I have a Candy Lime Green Nose Cowl off of my ZX14, The right tip is broken off, there is a crack just under where the mirror mounts on the right and by the right head light. there are minor scratches on the right side by the head light as well. $25.00
I also have a right mirror for the zx14. It has a small spot of rash on the bottom. No major damage, easily fixed $25.00
I also have a Cut down ZX14 Seat. Seat has been recovered with charcoal grippy vinyl and had a 1" gel/memory foam pad put in up front. Seat was intended for Drag racing but would work on the street for shorter riders as well. $80.00
I also have a EK DDR2 Non O-Ring 140link Drag chain. The chain has roughly 1000 miles on it. You will need to purchase a master link for it as the ones i have are used. $50.00
I also have an extended rear brake line for the ZX14. Silver braided steel line. $25.00
I also have a Hotbodies Candy Lime Green undertail, a spot of paint came off close to the bottom. it was covered with a hot bodies sticker. there are random nicks in the paint from rocks and one crack. nothing major. most are hardly seen when mounted. i also modified the very back to fit closer to the tail light. that part needs painted. $30.00
All Prices listed do NOT include shipping and are OBO.
Patrick
riteristrob
posted January 15, 2011 01:24 PM
Hey Thirteen - I'll go $70 to my door for the fork caps, oil fill cap and swing arm pivot caps. My email is robert.lyons1@comcast.net
TH1RT3EN
posted January 15, 2011 07:17 PM
email sent
Patrick
TH1RT3EN
posted January 16, 2011 06:14 PM
Oil Cap, Fork Caps, Swing Arm Pivot Caps are SOLD!
Everything else is still available.
Patrick
Hellmutt
posted January 17, 2011 12:58 PM
Off topic, but what brand shifter is on your bike?? I like the adjustability option and would consider one of those for easier setup on trackdays with rearsets
TH1RT3EN
posted January 17, 2011 01:12 PM
its a custom made shifter.
I had Justin from two wheel werkz fab it up for me. I love it so far, great fit and the adjustability is perfect for me. If you call him he may be able to set you up with one. he would need your lever to modify though.
Patrick
Hellmutt
posted January 18, 2011 12:43 PM
Another question, does the Hotbodies undertail you have fit with the factory undertail still in place? Or do you have to remove the factory setup to install the Hotbodies?
TH1RT3EN
posted January 18, 2011 02:51 PM        Edited By: TH1RT3EN on 18 Jan 2011 22:55
it fits over the stock undertail.
If you remove the sides of the tail section the very outside part of the undertail go above the bottom part of the tail section on both sides. Re-install the push pin rivets and your done. Easy install.
If your interested in it shoot me a pm and we can talk..
Patrick
TH1RT3EN
posted January 21, 2011 03:47 AM
Chain Pending sale....
Patrick
TH1RT3EN
posted January 24, 2011 04:09 AM
Patrick
TH1RT3EN
posted February 03, 2011 08:29 AM
Bump....
TH1RT3EN
posted February 23, 2011 08:48 AM
bump...
0.23104095458984 seconds processing time
