BIKELAND > FORUMS > CLASSIFIEDS > Thread: Multi function hub NEW TOPIC POST REPLY
gilberjj
Friend of Fast
posted November 05, 2010 03:19 PM        Edited By: gilberjj on 5 Nov 2010 23:19
Multi function hub
For Sale: Dynojet Power Commander Multi Function Hub
$100 Shipped
Paypal: gilberjj@gmail.com
In new condition, in fact, I don't think it was ever used, only removed from packaging. Perfect working condition. Comes with all harness except for map switch harness. If you want the map selection harness and switch, that costs another $30 and can be purchased here...
http://www.powercommander.com/powercommander/Products/MultiFunctionHub/powercommander_multifunction_hub.aspx
For questions, call me directly at (360) 481-8998
It can be hooked up to ANY bike with a Power Commander III USB. Here's what Dynojet's website says about the multi function hub.
The Multi-Function Hub allows users to access advanced expansion features. Several optional harnesses are available to permit both input and output to/from the module.
Map Selection Switch
Connecting the optional Map Selection Switch allows the rider to switch between two different maps within the Power Commander. For Touring Bikes this could be used to switch between a "fuel economy map" for long rides and a "full performance map".
For Sport Bikes it could be used for applications such as "Dry Nitrous Oxide" kits to permit the user to make the fuel mixture richer when activating the system. Additionally, if the Power Commander has an Ignition Module connected it can switch to a less aggressive timing map at the same time.
Gear Position/Speed Input
Fuel and ignition timing (when using the Dynojet Ignition Module) adjustments can be made based on gear position or speed. The multi-function hub makes it possible for the user to advance the timing in lower gears while retarding it in higher gears.
Boost Input
When using a Power Commander on turbo charged applications the Boost Input option makes it possible to have the fuel automatically increase with boost level. When an adjustable boost controller is used, this capability eliminates the need for re mapping each time the boost level is changed.
Programmable Output
Based on the data from the Power Commander and the inputs from the Multi-Function Hub, a solenoid, relay, warning light, etc. can be triggered. This can be used to activate items such as a shift light, Nitrous Oxide system, or air shifter.
chavcat
posted November 05, 2010 04:43 PM
PM sent
gilberjj
Friend of Fast
posted November 05, 2010 04:49 PM
PM sent
Thanks, but it already sold
That was fast..... those boys over on psychobike don't mess around when it comes to classifieds.....
0.32908511161804 seconds processing time
