BIKELAND > FORUMS > CLASSIFIEDS > Thread: 2005 zx10 ported head forsale NEW TOPIC POST REPLY
justoyz2
Justoyz Racing
posted May 09, 2010 02:22 PM
Racers,
I have an 05 zx10 ported head forsale.
-the head work was performed by Competetive Edge (Sarasota, fl)
-the head also have competition valve job
-.005 inch were milled from the head as well.
The head will be available after 7 Jun/10; I am asking 750.00 for the head, no core required. Those of you that may not know, this head has 1mm larger Intake and Exhaust valve in comparsion to the 2nd and 3rd generation zx10. This head was done because I was orignally going with a 3mm motor; I changed direction with my build and no longer require this head.
If you have any questions you can contact me at (justoyz1@yahoo or call/txt 808-542-2496)
Ezell
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
salsa1
posted May 20, 2010 01:17 PM
Is it designed specifically for a 3mm motor??
Salsa1
justoyz2
Justoyz Racing
posted May 20, 2010 01:39 PM
Yes, I provided all the information in the post. Not trying to be an ass; I am tired of answer the same question I already gave the answer to .......
salsa1
posted May 21, 2010 08:24 AM
No problem I will assume it is not compatible nor will benefit a stock factory ZX-10R motor.
Thanks!!
Salsa1
0.25552105903625 seconds processing time
