BIKELAND > FORUMS > CLASSIFIEDS > Thread: Dynatek ARC-2 w/ harness for ZX-14 NEW TOPIC POST REPLY
Kawracer
posted December 06, 2009 09:46 AM
$225 shipped or trade straight across for MSD launch master for ZX-14.
2004 & 2005 PMRA Street E.T. Champion
todd smith
posted December 06, 2009 05:29 PM
is this a 2 step or what opions
Kawracer
posted December 07, 2009 06:17 AM
More or less it creates a more powerful ignition spark......It does have a 2-step built into it as well as a timing retard option.
Here is what I copied from Dynatek's website:
Dynatek has introduced the ARC-2 for 4 cylinder Motorcycle applications. This CDI ignition is capable of producing over 50, 000 Volts at the spark plug, and has the highest spark energy of any CDI on the market. It is designed to optimize the ignition of the modified vehicles, providing the strong spark needed to develop peak power for turbocharged, nitrous oxide and high compression applications. Intelligent Spark Profiling in the restrike mode allows for less delay between successive sparks. It also features a built in launch limiter for drag style launches as well as a built in retard mode. The lightweight and compact ignition will be offered in plug in kits for select motorcycles & automotive models that will make installation a breeze, with no need to cut into the stock harness. For other models, a universal install kit is available. ARC-2 Features
Smallest Ligthest CDI on the market
Over 189mJ delivered to the coil per spark, the highest of any other on the market
Over 500V to the coil primary
Over 50kV to the coil secondary (assuming a 100:1 coil)
Intelligent Spark Profiling (ISP) allows for less delay Suzuki between successive sparks
Spark Restrike up to 4500 RPM
Provides this high level of output from as low as 8 Volts from the battery
Works with any 2 coil OEM ignition, with or without fac ignitor (some systems may require replacement coils)
Built in launch limiter, works from 2000-11900 RPM
Built in fixed timing retard function
Tach output
ARC-2 Technical Specifications
Operating Voltage: 8-20 Volts Operating Current: 7.0A @ 10, 000 RPM Maximum Operational RPM: 18, 000+ RPM Ignition Inputs: 2 Rising or Falling Edge Ignition Outputs: 2 Independent Channels Coil Primary Energy Max: 189+ mJ Coil Primary Voltage Max: 500+ V Restrike Window: 25 Cranksahft Degrees Launch Limiter Input: Single wire, ground to activate launch limit Retard Input: Single wire, ground to activate timing retard Tach Output: 12V square wave, 50% duty cycle Dimensions: 4" x 4.6" x 1.4" Weight: <1.25 lb.
0.27245497703552 seconds processing time
