BIKELAND > FORUMS > CLASSIFIEDS > Thread: Dunlop 211GP NTec 190/55 Takeoffs -- $75 NEW TOPIC POST REPLY
shiphteey
posted September 13, 2009 12:45 PM
Good tread down the center, came off of a bike that went down at the track so there is some oil on the side as you may be able to see in the pic. No abnormal wear, just the usual scuffs from it being on a racetrack. All I did was hose it down with water a little, no cleaner or soap has been used on it....figured the buyer would rather clean it themselves with whatever they felt was right (Simple Green?)
These are the expensive Made in the UK ones that require running significantly lower tire pressure than normal....18-20 psi cold! I ran one of these on an 07 GSXR 1000...even doubling the recommended tire pressure and running in under 32 degrees Farenheit street racing, once it got warmed up after the first run I had no issues all night long.
Taller than the stock 200/50 and 180/55 tires that some run on their 12R....which means if you are geared stock 18/46 and run this tire you can go over 200 mph if you have the power and distance to achieve it!
Shipping should be about $20 to the 48 states and I accept paypal.
A.
Gemini Motorcycles
shiphteey
posted September 14, 2009 06:12 AM
$75 shipped to the 48 states.
Gemini Motorcycles
shiphteey
posted September 14, 2009 08:13 PM
$65 shipped to the 48 states!
Gemini Motorcycles
0.28492617607117 seconds processing time
