BIKELAND > FORUMS > CLASSIFIEDS > Thread: Busa Parts Forsale NEW TOPIC POST REPLY
Spaz
posted October 28, 2002 09:11 AM
Busa Parts Forsale
1) 99-01 Radiator
2) Front Turn signals
3) Complete Three peice Lock set with key
4) Upper Fairing Bracket Mint
5) Front rotor with 20 miles on it Mint
6) Right and Left Front Foot peg Brackets complete.
7) 2000 wiring harness
8) Two rear Shock's low mileage
9) Two freshly done Clutch mod's
10) NEW VORTEX Rear Sprocket 40t
11) 2001 ECU
12) 2 Sets of coil stick's low mileage
13) 2000 Fuel pump
14) Cush Drive - Complete with Sprocket
15) Two sets of brake calipers with lines
16) 4 rear brake calipers
17) Rear brake arm
18) Rear master cylinders complete with reservoir and line
19) Clutch master cylinder
20) Front brake master cylinder
21) BRAND New Swingarm
22) One rectifier
23) Plastic chin around oil cooler
24) 2 Anti-freeze overflow bottles
25) 2 taillight brackets
26) 2 license plate brackets
27) 1 rear seat latch with cable
28) Gas tank mounting bracket
29) Steering stabilizer
30) 5 rear stock sprockets perfect shape
31) 3 front stock sprockets
32) 2 kickstands complete with mounting brackets and switch
33) Right foot peg bracket complete with brake lever and foot peg
34) Right front foot peg bracket only
35) Left front foot peg bracket complete
36) Left and right rear turn signals
37) Stock fan blade
38) Lower triple clamp
39) Upper triple clamp cover with Hayabusa logo
40) Compleye Fan Assy.
41) Mint head light with bulb's
42) Complete front end
43) 99-2000 Aluminum Rear subframe Mint
44) 2001-2003 Rear Steel Subframe
45) 2000 Blue & Silver Gas tank Mint
I also have assorted censors, hoses, and clamps for any part of your Hayabusa. If you do not see it listed, I probably have it. Don't hesitate to ask.
E-Mail me @ SpazRacing@mchsi.com
0.24916005134583 seconds processing time
