BIKELAND > FORUMS > CLASSIFIEDS > Thread: SPEEDO HEALER KAWASAKI NINJA ZX6R ZX9R ZX10R ZX14 650R NEW TOPIC POST REPLY
Rideharder
posted July 17, 2009 04:10 PM
$104 and free shipping
Never been opened still sealed..
contact me at speedaholic.net@gmail.com
Speedo Healer Version 4 Kit
Fits the following Kawasaki Motorcycles
98-04 Ninja ZX-6R
07-09 Ninja ZX-6R
03-04 ZX-6RR
05-08 ZZR600
04-05 ZX-9R
04-05 ZX-10R
04-06 ZX-14
04-06 ZZR1400
04-06 Z750
03-06 Z1000
06-09 Ninja 650R
Factory speedometer error can run as high as 10% on modern motorcycles. Add in a sprocket gearing change and it can throw the speedometer off by 15%. Not only will your speedometer be off, but the sprocket change will also cause higher odometer readings. Higher odometer readings can create a negative resale factor for no valid reason. The Speedo Healer is an inexpensive, convenient and simple way to fix your speedometer and odometer. The Speedo Healer is compatible with all motorcycles with non cable driven speedometers.
In a nutshell, the Speedo Healer is an electronic device which will enable your bike's speedo and odometer to show realistic information. In addition, the Speedo Healer can convert Km/h to MPH in real time. In regard to the technical specifications and included functions, the Speedo Healer is the best calibrator currently available. Speedo Healer V4 Plug in play units re-calibrate speedometer reading on re-geared motorcycles
As an added feature, the Speedo Healer Top Speed Memory recalls your recent real top speed to your factory speedometer display at the press of a button and will still work after the ignition is cycled off and back on later.
Typical uses
Eliminating "factory inaccuracy", which may be as much as 10%
Account for changes in tire size/profiles
Make gear ratio changes, such as sprocket conversions on motorcycles
Use to output lower MPH and by-pass (alter around for top speed Bonneville or radar-trap runs) the built-in factory speed limiter on specific Honda, Kawasaki, and Yamaha bikes, such as the CBR1000RR, R1, ZX10R and ZX14.
Note: you need the GIpro w/ATRE to remove the speed limiter on Suzuki motorcycles (check our listings for the Glpro w/ATRE)
Adjust for new speedo face-plate with different scale
Requirement for absolute accurate odometer or speedometer
Requirement to characterize the display unit of the vehicle (stability, error % and linearity)
What do you gain with Speedo Healer?
Accurate speedometer and/or odometer no matter what you change on your vehicle
Your odometer won't show more miles/kms than you ride (RESALE VALUE!)
Top Speed Memory (Ever wondered HOW FAST you were going?)
Safety: your speedometer will always clearly indicate your actual speed, without lag
Optimal performance (certain vehicles require accurate speed signal to deliver the most performance)
Product highlights
Widest calibration range along with the finest increments (0.1%)
The best accuracy (0.025%)
Have the most features
Plug-n-Go Kits are available for the major Japanese bikes
Quick and easy setup through the on-line calculator
100% weather proof design, it is built to last
The lightest re-calibrator with the most compact dimensions
Each unit is extensively tested prior to shipping. Guaranteed to work.
The digital V.4 release also includes:
New User Interface: Easier to program, review and update the stored parameters
Extended Calibration Range: Works even for special applications, like with different engine/gauge combinations, bike engines powering cars, etc
Detachable Remote Button: Top speed recall now comes with detachable TSM button standard on all units
Smaller & Lighter: 30% smaller and lighter. By far the smallest calibrator on the market!
Improved Layout: Redesigned harness fits into smaller spaces
Dual Stored Data: Allows storing of two independent calibration values, and switching among them by the press of a button. Has clear visual confirmation of the value in use. Useful for road/track use when changing gearing. Also, easy to bypass speed limiter when on the track.
Km/h to MPH Conversion: Allows you to review and enable/disable conversion at the press of a button.
Lower Power Draw: Reduced power consumption with auto-standby. Works from as low as 3v supply.
Each unit is extensively tested, and comes with a TWO YEAR manufacturer's replacement guarantee (Manufacturer's guarantee covers normal use and correct installation. The product should not be damaged or subjected to over-voltage.)
  Ignore this member    Click here to visit Rideharder's homepage.
Rideharder
posted July 18, 2009 02:37 PM
Sold!
0.22236800193787 seconds processing time
