BIKELAND > FORUMS > CLASSIFIEDS > Thread: 1394 ZX12RR 6,500 OBO Fresh Build NEW TOPIC POST REPLY
mrjobe
posted July 02, 2009 09:28 PM
I’ll try to make a long story short,
My wife and I have had 4 kids living with us for the past two years. Today we signed the paper work to adopt them and decided it would be cool to take them on a family vacation.
Disney World it is.
To make it happen I’m selling a toy…long story short either the bike or the car has to go.
Contact James @
405-912-4782
Pawnpusher71@yahoo.com
Moore, OK. 73160
The car is a 1973 Camaro 350/350 w/3.73’s its pretty nice $8,000. Look for it in a separate ad.
The bike is a prostreet 2000 ZX-12R $6,500. OBO or trades with at least $3,500. It has a clean green no lien Oklahoma title in my name. Last year I spun a bearing in the stock motor and replaced it with a built 2002 ZX-12R. Odometer shows 15,500 +/- but is way high due to gearing.
This bike has custom paint and must be seen in person to be appreciated. It has a whole lot of parts and is built to go quick.
I bought the motor from lunacy racing. This motor ran low 8’s @ 160+ in their chassis. It was rebuilt and received new bearings and rings at the end of last season. The motor is fresh & has very low miles. < 500. Its bored stroked cam’d and the tranny is race cut. RPM Dyno’d it @ only180hp. They assured me that’s very good for their dyno and that head/cams busa’s dyno less. I made the mistake of using C16 for the dyno run and that cost an estimated 10hp. The bike should do a lot better with the right fuel and a little ignition timing. That’s with out the nitrous. There is a 40 shot on the bike but the motor has never been sprayed.
MAKE NO MISTAKE, the bike pulls harder than you can imagine and you wouldn’t know it had more in it unless I had told you up front. The bike is nuts and I will try to get it down the track to see what kind of # I can put up.
I’ve ridden it to work a couple of times and up and down the highway just getting it sorted. It runs very well on 91 w/a little 104 octane booster. This is a killer street legal dragbike!
The lower fairings are not on the bike at this time. I had them off for the dyno runs and the right side will need to be notched to clear the sidewinder.
MOTOR:
1394cc
Falicon Crank
JE Pistons
Muzzy 00’ Race Cams
Muzzy Valves & Titanium springs
Muzzy reed block-offs, w/Crank case vent
Muzzy sidewinder
Ape adjustable cam sprockets
Koenig low profile billet oil pan w/swinging pick-up
The Transmission has been race cut.
New clutch fibers & steels
Dyno Jet PC3 USB
MPS Kill switch (AMA legal)
Vortex sprockets front and rear. Front (-1), Rear (48 tooth) w/a 530 chain
Swing arm extensions (Myrtle West 3-7”?)
PMR lowering links
Shinko rear tire
Fender eliminator w/integrated rear turn signals
Flush mount turn front signals.
40 shot of nitrous
2000’ motor is included. The crank can be welded up and turned into a stroker for around $350. Most every thing should be there although as-is the crank and rods should not be used.
I also have a spare fuel pump assembly and a walbro GS307. (The high flow muzzy pump)
Note: The pics show the bike with the lowers on it and a hindle pipe. The lowers are not on it at this time but are included and the bike now has the full Muzzy sidewinder.
Pics: http://www.geocities.com/state_surplus/zx12r.JPG
mrjobe
posted July 04, 2009 01:12 PM
I have gotten a ton of questions regarding the dyno #'s
About the dyno, C16 was used for fuel by mistake. I didnt realize it until after, I had meant to use C12.
The dyno #'s are uncorrected and on a dynojet dynometer which is in my understanding conservative.
The cam's are degreed just under what muzzy recomended to allow for a bigger torque curve. This bike has busa beating torque and comes on @ 3,000 rpm. The stock motor had to be turning 7,000.
You wouldnt belive it unless you rode it. This is an entirly different bike now.
The bike needs to have the ignition advanced. The module for the PC3 is $350
Popular opinion is, the C16 robbed 10hp +/-, uncorrected would account for 10+/-, I've heard dyno jet is 20% conservative, putting the cams @ muzzy recomended 105/106 would gain some hp, ignition timing would gain 5-10.
I'm not making excuses, it is what it is,but yes the motor should be 220+.
I think I'm going to keep the bike together and just keep dropping the price until it sells.
Its too nice to scap out.
NOX
PMRA / TMRC Super Street 4022
posted July 05, 2009 09:38 PM
RPM as in Eldorado, AR
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
mrjobe
posted July 06, 2009 09:00 AM
Whoops, I should have been more specific.
RPM in OKC, Buddy i think? Said his busa guys always left dissapointed.
Price drop $6,000 OBO
0.25560188293457 seconds processing time
