BIKELAND > FORUMS > CLASSIFIEDS > Thread: NEW Cometic Noxbox-2 Nitrous Controller F/S NEW TOPIC POST REPLY
jessejames82
posted January 21, 2009 11:07 AM
Hey guys I want to go another way on the bike so i have a BRAND NEW in the box never installed Cometic Noxbox-2 Nitrous Controller F/S $270 TYD..here is from the website pm me
Drives two nitrous stages and purge solenoid. NOX BOX-2 is capable of 40 amp output on each stage.
Each stage is independently programmable based on throttle position, RPM, vehicle speed and time delay, with the ability to lockout first gear. NOX BOX-2 adds capability for RPM or time based progressive control.
Output for purge solenoid (requires external relay). Programmable automatic purge when system is armed.
Flexible RPM input compatible with high voltage coil drive (vehicles with coil packs or distributor ignition), standard 12 volt tach signal, or low level logic drive (newer vehicles with coil-on-plug).
General purpose input/output (GPIO) terminal. Programmable for use as shift light output, additional stage enable input, or control output for ignition retard.
Status LED output (ideal for use with arming switch containing LED).
Built-in data logging. Ideal as basic vehicle data logger during dyno tuning or drag racing. Logs data whenever system is armed. Stores last 5 minutes of data at 10 samples/second.
Data logged includes throttle position, RPM, vehicle speed, status of all inputs and outputs, and two 0-5 volt analog inputs.
0-5 Volt analog inputs are compatible with Daytona Sensors single or dual channel WEGO II systems for logging wide-band air/fuel ratio data.
Heavy duty industrial grade clamping terminal blocks allow easy and reliable hookup without soldering or crimping.
Compact size: 4.1"L x 2.8"W x 1.1"H (not including mounting feet and terminal block).
USB interface to laptop PC. Powerful Windows software for programming controller and downloading logged data. Please visit our website for complete details and downloads
PC Link Nitrous Software:
· Used to establish controller scale factors, general setup parameters, and independent control parameters for each nitrous stage.
· Program control strategy based on throttle position, RPM and vehicle speed windows, time delay, and first gear lockout.
· RPM or time based progressive control(NOX BOX-2 only). Easy graphic editing of ramp with 32 points spaced at 250 RPM or 0.25 second intervals.
· Use of RPM and vehicle speed inputs is optional. Control strategy can be as simple as a time delay or time based progressive ramp initiated by a wide open throttle switch.
· You can download and upload to the module, open and save files to disk, and print setup values including graphs for progressive ramps. Includes comprehensive on-line help system.
Orient Express Rider
SuperSport ZX 14
6.000 8th mile
kawpower
Mr kawasaki 2 you!
posted January 23, 2009 07:48 AM
do u still have the crank?
jessejames82
posted January 23, 2009 08:09 AM
sold
SuperSport ZX 14
6.000 8th mile
jessejames82
posted January 23, 2009 02:19 PM
crank sold no the controller
SuperSport ZX 14
6.000 8th mile
0.22707891464233 seconds processing time
