BIKELAND > FORUMS > CLASSIFIEDS > Thread: possibly selling Muzzy full system NEW TOPIC POST REPLY
posted January 19, 2009 09:13 PM
I want to change to a Hindle so when i do, my Muzzy stainless system with aluminum can will be up for grabs. I went 148mph with this pipe, on a stock 01 12R(in 07) with K&Ns and a pc3r. im about 190 #s suited (i can get you the map i used)
the mid pipe has a bung brazed on for a wideband O2 sensor, and has a setup to evac the crank case to a section further down stream(doesnt affect afr readings) like you see on drag cars (they go from the valve cover to the header).
make an offer and ill put you at the top of the list
posted January 22, 2009 02:09 PM
300 plus shipping?
posted January 23, 2009 05:08 PM
officially for sale got a Hindle lined up
more pics
the crank case evac mod (I can remove this if you dont want it, ill need one for my new pipe) this works the same way as the normal crank case vent mod as it puts a vaccum on the crank case for a couple hp, but you cant data log with the normal crank case vent mod. with this you can as it puts the air downstream of the O2 sensor. kinda visible kinda hidden. the big piece is the one way check valve. you cant really see much of it standing beside the bike
slight damage on the bottom of the pipe from the previous owner. didnt hurt performance any (see mph)
(pic from designing a custom pan)
0.25645208358765 seconds processing time
