kawi_ryan
posted January 14, 2009 09:05 PM
FS: ZX12R CP Pistons NEW IN BOX
I have (6) CP Pistons for a ZX12R. They are brand new and come with rings and the pins for them. $750 OBO shipped
Specs
Bore diameter: 3.3858 Forging: X85
Clearance: 0.0020 Piston size at gauge point: 3.3838
Compression height: 0.986
Top groove width: 0.04 Top groove diameter:3.103
2nd groove width: 0.048 2nd groove diameter: 3.073
3rd groove width: 0.078 3rd groove diameter: 3.102
Intake valve relief: -0.17 Exhaust valve relief: -.170
Profile: Pin diameter: 0.787
Dish depth: -0.05 Pin length: 2
Dome height: 0.125 Lock type: .50 Wire
Gram weight: 230 Cam profile: 10MC45M12
kawi_ryan
posted January 17, 2009 03:11 PM
$700 shipped... cmon guys
posted January 17, 2009 03:59 PM
did you find out what CR they are? that might help a sale
kawi_ryan
posted January 17, 2009 04:19 PM
I emailed CP to double check the CR... I should know by Mon.
chavcat
posted January 18, 2009 07:56 AM
Should be 12.5:1 if is a standard CP piston.
Texas12R
posted January 18, 2009 08:30 AM
email sent to rob marsh........
kawi_ryan
posted January 18, 2009 08:39 AM
i believe it is chavcat, just double checkin..... Email responded Texas12r
kawi_ryan
posted January 19, 2009 07:21 PM
To the top....
kawi_ryan
posted January 20, 2009 09:57 AM
PISTONS are 13.5:1 when using a .040 head gasket, 0 deck clearance, & stock stroke
posted January 20, 2009 11:22 AM
i dont think many builds have zero deck height, but i measured a used cometic HG as .032. so the pistons can be "in the hole" .008 and have that cr
kawi_ryan
posted January 20, 2009 01:49 PM
Edited By: kawi_ryan on 20 Jan 2009 21:49
true...... thats the info I was given though from CP
posted January 20, 2009 02:10 PM
another way to look at it is if the pistons have .040 for quench height you will get that cr with a stock stroke. thats a pretty standard number on a build.
chavcat
posted January 20, 2009 07:22 PM
Ryan are these standard CP pistons or custom pistons. CP makes 12.5:1 2mm over pistons and 13.5:1 for drop in stock displacement only.
kawi_ryan
posted January 20, 2009 08:06 PM
Theyre 86mm ... thats what i was told..... 13.5:1 on a stock stroke..... Im not sure of the stock piston size but I was told these were 86 mm
posted January 21, 2009 12:28 AM
stock is 83mm
chavcat
posted January 21, 2009 04:25 AM
They must be custom pistons as CP does not offer 86 off the shelf.
kawi_ryan
posted January 21, 2009 08:11 AM
Ok... Well I guess they will need a slight bore....
posted January 22, 2009 10:39 AM
are you sure on the size? are they custom made?
kawi_ryan
posted January 22, 2009 02:49 PM
Thats what I was told. I gave chavcat the job # so he could contact CP
kawi_ryan
posted January 24, 2009 06:41 AM
SOLD!!!!!
