BIKELAND > FORUMS > CLASSIFIEDS > Thread: Wanted.. ZX12 Engine NEW TOPIC POST REPLY
thutch26
thutch26
posted January 14, 2009 11:36 AM
Must be in good running condition from the top to the bottom ...I'm posting for a friend.. LMK~~~ thanks!
woppi
posted January 14, 2009 01:11 PM
take a look at ebay motors !!!
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
kawi_ryan
posted January 14, 2009 07:29 PM        Edited By: kawi_ryan on 15 Jan 2009 03:31
I have a 2005 ZX12R Motor/tranny/ wiring harness/ ecu FOR SALE Im asking $2350 (cheaper than ebay w/ less than 5k miles) Best offer takes it....
kawi_ryan
posted January 15, 2009 06:11 AM
let me know if you're interested in this engine..... send me an email if you like..... r_marsh@rocketmail.com
thutch26
thutch26
posted January 15, 2009 10:42 AM
thanks... but i need a motor from a 2000-2001... from what i understand the engine to frame mounting points on the heads are different...
posted January 15, 2009 12:33 PM
to fit a 02+ motor in a 00 or 01 you just need to drill and tap the head for the early style motor mounts. the head is basically the same, they just didnt take the time to drill and tap that section on the later ones. very simple to have done
kawi_ryan
posted January 15, 2009 12:48 PM
See there ya go... you could have it tapped to fit. And have a motor from an 05.... Let me know what you think......
woppi
posted January 15, 2009 12:59 PM
yes they are !
but you can change the cylinder heads !!!!!!!!!!!!
woppi
kawi_ryan
posted January 15, 2009 01:28 PM
you could change the heads or you could just tap this one for the mounts (not that difficult) .... and im selling everything for $2350..... engine and tranny , wiring harness ad ECU....
thutch26
thutch26
posted January 15, 2009 08:55 PM
is the harness and ecu the ame or will those need changed out also? the guy looking for this just has a bad tranny and I figured he could just get a newer motor with less miles then his for about th same price..
Ryan how many miles on this motor?/tranny? is everything in working order? all stock?
posted January 15, 2009 11:04 PM
not sure about the wiring harness, but some ecus have diff plug connectors, i know my 01 and dads 00 wont swap just ecus, but if you swap the wiring harness too it will work. the 05 is a 32 bit ecu vs the older 16 bit ecu.
woppi
posted January 15, 2009 11:14 PM
at 2004 there is an other harness !!!! dual throttle flap !!!!!!!!
@thutch26
you can use all your parts from your old engine !!! harness, and, and ,and
all other parts will fit !!!!
2005 engine ---- drill the holes to mount with the old brackets ??
or you change the cylinder heads ------ cylinder heads are all the same !!!
woppi
kawi_ryan
posted January 16, 2009 02:37 AM        Edited By: kawi_ryan on 16 Jan 2009 10:38
Everything is in great condition. All of this has less than 5k miles on everything. And is totally complete..... nothins missing......all stock. And im not sure if you gotta change it out. But if you want to mine comes with the parts neccessary......
0.60533404350281 seconds processing time
