BIKELAND > FORUMS > CLASSIFIEDS > Thread: digital gear indacator NEW TOPIC POST REPLY
Bobbydigital17420
posted July 23, 2008 09:31 PM
im lokkin to get a digital gear indacator any one have one for sale let me kno i ride a zx12
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
slykittycat
posted July 29, 2008 08:00 PM        Edited By: slykittycat on 29 Jul 2008 21:01
Are your looking for something like this
  Ignore this member    Click here to visit slykittycat's homepage.
slykittycat
posted July 30, 2008 06:39 AM
How to build a Digital Gear Position Indicator for a ZX-12R (ZX1200-A1, A2)
http://www.angelfire.com/wa3/r.miklos/shiftindicator/gearindicator.htm
this is where i found the info to build your own
if your not into building one let me know i can make one for you for 75.00 shipped
but its much more fun to make your own
slykittycat
posted July 31, 2008 04:35 PM        Edited By: slykittycat on 31 Jul 2008 17:46
kaw12
hey thats cool, i looked at the instructions and looks fairly easy but, how long did it take?
takes about about 2 hours to assemble and solder all the parts ((check twice cut once method)) lol and another hour to take the dam bike apart run wire to front and connect wires to ECU again ((check twice cut once method))
i used an ethernet cable and an ethernet jack on the display side so i could run the wire and connect it to the display 8 wires worked well and ethernet wire for the ecu connection end hardwired to the pcb of the gear indicator and wire tapped the ecu wires 7 then ran power and ground wire off pcb to power and ground of brake running light
link to 7-Segment Red LED Display 1.5'' Common Cathode
http://cgi.ebay.com/6-pcs-7-Segment-Red-LED-Display-1-5-Common-Cathode_W0QQitemZ160240863445QQihZ006QQcategoryZ66954QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
0.26709294319153 seconds processing time
