BIKELAND > FORUMS > CLASSIFIEDS > Thread: ZX 14 Cycle Logic Turbo with External Wastegate F/S NEW TOPIC POST REPLY
jessejames82
posted May 18, 2008 02:09 PM        Edited By: jessejames82 on 18 May 2008 15:29
Alright guys I have been semi sponsered to run supersport so i have no need for a turbo anymore killer deal...$3500 TYD Retail is over $5500.... Cycle Logic Turbo with ONE of a kind external wastegate (with 3.5 5.5 and 8.5 springs $ 30 a piece) the bike went at 60'' 8.70s at high 160s ... here is all you get with the kit straight from the site ....Kawasaki ZX-14R Turbo Kit 2006-2007 This is the most awesome Turbo kit in production for the Kawasaki ZX 14r. This New kit on the 2006-2007 ZX14!!! We build the finest Billet parts available anywhere. We use a dual ball bearing turbo unit by IHI for the quickest spooling and the most throttle responsive turbo set up on the planet!!! It is designed for an "All Stock" engine to produce 260RWHP. We have designed our own Billet aluminum boost sensing fuel controller. No one anywhere has a fuel controller as small, light and effective as this one. Look close at all the images to notice the "fine" engineering and CNC machining we do. This is the best a production kit can be. When you are ready, you can add Forged rods, pistons and a secondary fuel injector controller for BIG power. The turbo unit in every kit is capable of producing over 435RWHP.
The external wastegate is one of a kind a Tial 38MM so some of the parts list below (from manafacturers site wont be included)
and External K n N Airfilter
Other parts included are:
• 321L stainless steel turbo header (ported and polished)
• IHI vf22 turbo configured (set up specific) ZX-14r
• Waste gate actuator (preset to 8PSI boost)
• 321L stainless down pipe
• Stainless steel slash cut dum pipe (standard)
• tunable megaphone muffler (exits behind right foot peg)(optional)
• 6061 aluminum charge tube
• Silicone couplers
• Stainless steel T-bolt charge tube clamps
• Billet CNC machined main air inlet
• Billet CNC machined frame block off with to pressure ports for boost gauge and fuel pressure control
• Glycerin filled boost gauge (optional)
• Silicone vacuum control hoses
• Billet aluminum air filter cartridge cover
• High performance fuel pump tower (core exchange)
• Billet CNC machined fuel controller
• Billet CNC machined fuel controller bracket
• Electric oil evac pump
• Billet CNC machined oil evac pump mount
• Billet CNC machined oil return port
• Lower crank case breather vent air filter (K & N style)
• Oil injection flow control valve
• Stainless XRP oil feed line
• Billet CNC machined turbo oil out flange
• High pressure fuel lines, connectors, clamps
AND a Fuel Pressure gauge AND Boost Gauge AND a custom map AND I have all the dyno maps and everything... that all comes with the turbo $3500 TYD ....I also am selling a AMS 500 Boost controller for $275 shipped and a Innovate Wideband (BRAND NEW NEVER INSTALLED) The Basic Kit ($349) includes the LM-1 meter, a Bosch wide-band oxygen sensor, 10 ft sensor cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and quick-start guide The RPM Kit ($429) is comprised of the basic kit plus the LMA-2 (RPM Converter.) This cable contains a circuit to convert a tach signal into an analog RPM signal that can be logged by the LM-1. This cable also has 4 additional terminal screws to tap into and log other 0-5 V analog sensors from your vehicle ... I have the LMA 2 so it is everything you need... RETAIL is over 400 ...$350 TYD for the wideband ... PM me or call 727 698 6846 .. I will seperate the Turbo with AMS 500 and Wideband I have Pics just ask will post very soon..I have been on the bike for about 50 passes Call me with questions - Jesse ..p.s. add 3% for paypal
Orient Express Rider
SuperSport ZX 14
6.000 8th mile
ninja12
posted May 18, 2008 07:50 PM        Edited By: ninja12 on 18 May 2008 20:51
dibbs on the turbo.....I'll call you in the morning.
BlackMagic14
posted May 19, 2008 03:47 PM
Is it sold??
thutch26
thutch26
posted May 19, 2008 05:57 PM
I'm tryin to get his arm 4sale... I guess he has yet to get on here today!!
ninja12
posted May 20, 2008 10:53 AM
yes, it's sold!
0.29105806350708 seconds processing time
