BIKELAND > FORUMS > CLASSIFIEDS > Thread: Turbo Kawasaki 340hp NEW TOPIC POST REPLY
turbogpz
posted March 03, 2008 04:14 PM        Edited By: turbogpz on 3 Mar 2008 16:16
Selling my "TurboGPZ", starting another turbo project....
$4500
Ebay:
http://cgi.ebay.com/ebaymotors/Kawasaki-Ninja-Turbo-Kawaski-340-hp-ZX-Hayabusa-GSXR-R1-Suzuki_W0QQcmdZViewItemQQcategoryZ50019QQihZ013QQitemZ230228547704QQrdZ1QQsspagenameZWDVW
1983 Gpz1100 Turbo Kawasaki 340HP Stand-Alone Engine Management System
Engine Management System:
EMS stand alone complete engine control system, Hand held and Laptop programmable. Wide Band Bosch O2 sensor, Launch control, 4 digital and analog outputs, Dual redundant ignition systems, boost control, Data logging and analysis, proportional turbo oiling system, High Boost control optioned unit.
Chassis:
Front End: Re valved, Progressive Front Springs, 2" Lowering Blocks, New Bearings and Seals
Fast By Gast Steering Stabilizer
Rear End: McInTosh 4" Arm w/ AMA-Dragbike approved chain guard
U.F.O converted 17" rear wheel, Chrome-Molly brake arm
Lowered UniTrak rear link
Engine:
Head : FBG turbo porting, Oversize stainless valves, new guides, MTC valve springs, 8-spark plug head setup FBG converted cam chain adjuster.
Block: 1260cc Weisco Sleeve and Piston Kit
Cases: Over Board cases with APE case and Block stud Kit
Crank: FBG crankshaft
Transmission: FBG turbo cut gears, MTC Gpz to J conversion, billet output shaft, MTC Snow Flake lockup clutch w/ spacer, Pogue clutch roller pusher kit.
Fuel System: Dual staged boost referenced fuel pumps, Mallory fuel pressure regulator, 480cc injectors
Intercooler: Spearco 6x9 core, 72% efficient. Laminar air flow diffusers for increased cooling.
Turbo: Michigan Turbo, T3/T4 Garrett turbo, RE Engineering header, 38mm waste gate w/10psi boost first stage.
Remote turbo oiling System: computer controlled oil supply system, Remote oiling keeps clutch and engine debris from turbo unit.
Co2 Pneumatic shifter, controlled by horn button, w/ arming switch.
Boost control: gear based staged system powered with CO2 for supreme accuracy.
Shift Light: Dyna shift light controlled by EFI system
High output Alternator
Corbin Gun Fighter Seat
Optima Battery
Boost Guage
Fuel Pressure Gauge
Dual independent/redundant ignition systems
251hp pump gas, 343hp race fuel, Tuned Motorheads Cleveland Ohio.
1badzx12r
posted March 03, 2008 04:30 PM
one nice gpz ....were is it located at
1badzx12r
posted March 03, 2008 04:32 PM
never mind to far from texas
posted March 04, 2008 08:09 AM
might get some hits on 750turbo.com too
TRNorBRN6001
posted March 04, 2008 04:08 PM
Bump for one perty bike! I had the silver GPZ1100 minus the hairdryer. If you don't sell it, bring it to the Texas Mile and show some people how real Kawi runs. There will be a few TFA members out as well.
TFA 200MPH CLUB MEMBER!
1badzx12r
posted March 05, 2008 05:12 AM
now thats and idea ... cuz i'll be there
posted March 05, 2008 01:23 PM
Nice bike!
keep your classic.
Nobody will appreciate it as much as you, and nobody will pay near what you have into it...
Thats what i would do.... in 10 years you would get double what your asking for it now....
maybe a museum might pick it up....
GUNNER
posted March 05, 2008 04:19 PM
OH I appreciate it !! I had it's clone back in 83. 1260 turbo 66" wheelbase MONSTER!!!
0.24334311485291 seconds processing time
