BIKELAND > FORUMS > CLASSIFIEDS > Thread: FS HyperPro RSC Dampner ZX12 02+ NEW TOPIC POST REPLY
238mph
posted January 17, 2008 08:20 AM        Edited By: 238mph on 17 Jan 2008 08:24
Like new, but it is used... Hyper Pro RSC Dampner fits 02 and up ZX12
$679.00 new.
Asking $375. I do PayPal jd3@jd3.com is my email.
http://www.hyperprousa.com/Active.htm
Active (RSC)
(Reactive Speed Control)
The HyperPro RSC is the only active valving damper available. As steering speed increases, the internal valving changes automatically to increase the damping effect. This results in a light, easy handling ride at low speeds while still keeping the heavy damping during extreme situations
Stroke 75
Damping can be adjusted in a wide range, divided in 22 positions. This results in a smooth, light and easy handling at low speeds combined with heavy damping that AUTOMATICALLY kicks in during extreme situations. No other aftermarket company offers anything even close, a Hyperpro Exclusive feature found only on the RSC damper.
Pilot Powers took me to the grave, and brought me back...
  Ignore this member    Click here to visit 238mph's homepage.
stuart racing
N.H.R.A . Dragracing.
posted January 17, 2008 03:05 PM
How hard/easy is this one to mount to the bike????I've seen some where you have to drill into the frame/.airbox tap,ect.ect.ect....
Thanks alot,
Paul......
HG
posted January 17, 2008 07:21 PM
Very easy to install...Thats actually the set up that Muzzy sells. With a little motivation it should take less than an hour. No drilling....
Thanks alot,
Paul......
238mph
posted January 17, 2008 07:49 PM
It's a bolt on, something you can do in an hour... maybe 2.... It bolts onto the bracket
that holds the instrument cluster.... then clamps to the fork tube.
0.36855816841125 seconds processing time
