BIKELAND > FORUMS > CLASSIFIEDS > Thread: Parting out ZX12R race bike. NEW TOPIC POST REPLY
NOS1290
posted October 22, 2007 09:35 AM
I am just starting to put together a list of the race parts and stock parts I have, and will be selling soon on ebay. PM me with any questions or offers you may have on these parts or others I may have for a 12.
Lock up clutch
Muzzy Billet clutch basket
Muzzy inner hub
Dry NOS system for 12
modified cases
Carrillo Rods
Megacycle Cams
Undercut Transmission
Step down drag Seat
Muzzy Ti Header
Carbon Covers
Extended 12.3k rpm ECU - Dave Owen
6+ Track Dynamic Swingarm
Wet spray (in the frame) manifold for NOS
balance injectors w/ throttle bodies
Oil Pump blueprint
Bonniville box
Air Shifter kit (with linkage)
(8) Sprockets (drag, landspeed and everything in between)
vacuum system
Mirrors / block off plates
Front axle leaded (weighted)
Rear Axle alloy Light weight
Adjustable Rear Links
Muzzy Fuel Pump
Rear Duck Tail - custom
PCIIIr
Steering damper
BMC Air Filter
2.0 MM Clutch Steels (20)
Lead ballast (12lbs under radiator)
Pirrelli Supercorsa Tires (like new)
Adjustable kick stand for lowered bikes
stuart racing
N.H.R.A . Dragracing.
posted October 22, 2007 11:46 AM
How bout the drag seat...I have a 02 zx12r..Covered or not ect.ect.How much...
Thanks,
Paul
stuartracing@gru.net
NOS1290
posted October 22, 2007 11:53 AM
the seat will fit your bike and will drop your seat hight by over an inch. The seat is sewn together with material from factory seat. There is a step about 5 inches from the front that keeps you pinned to the tank, but allows you so slide back and up after the launch.
ninja12
posted October 22, 2007 01:30 PM        Edited By: ninja12 on 22 Oct 2007 14:31
What the ticket on the ballast?
and rods?
I'm interested
stuart racing
posted October 22, 2007 04:13 PM
Cool,
How muc????
Paul...
rquinn
posted October 22, 2007 04:19 PM
Muzzy fuel pump intrerested,cams,and cases
RON QUINN
NOS1290
posted October 22, 2007 04:46 PM
Ninja12
Ballast is a one off custom. It fits below the radiator and clears the stock bodywork. It weighs about 8.5 lbs and attaches on the cylinder head, on the rear pan, and on the oil cooler. It definitely helped in coming out of the hole at WOT. Its almost impossible to see with visual inspection. Price delivered $60. I have a leaded front axle as well. I can weigh this when I get it off the bike but it adds a couple of pounds as far forward as possible. Price delivered $40.
Stuart racing,
Seat is $85 delivered. If you PM me your email I will send photos.
Ron Quinn,
Cams are Megacycles X1 on the intake; .405 lift and 255 duration and X5 on exhaust; .384 lift and 251 duration. These duration numbers on the cam card are at zero clearance. I didn't get anything at all like that at .040" when I degreed them in. Cams have adjustable cam sprockets installed. They also come with an adjustable cam sensor trigger wich is necessary if you are putting them on 00 or 01 and later heads. $425 for cams delivered.
Cases have been modified by HMP. They have 4 sprayers pointed to the bottom of each piston, and they also have oil restrictions in the output to the alternator and tranny to increase flow to the rods. They were also line honel. They have never had a spun rod or main bearing in these cases and crankshaft combination. Cases are $425 delivered. Stock stroke Crank is in great shape (never rewelded) and is also for sale.
Muzzy fuel pump is 3 seasons old and is 75 dollars delivered.
stuart racing
posted October 22, 2007 05:50 PM
you have mail........
bloodso
posted October 22, 2007 05:57 PM
Sent you a PM about getting the damper.
rquinn
posted October 22, 2007 05:58 PM
PM me your number
RON QUINN
say-what-u-want
posted October 22, 2007 06:44 PM
wow is it Christmas p.m sent
it's all good(laugh now cry later fools)
posted October 22, 2007 07:10 PM
im interested in the lock up and the muzzy pump if rquin doesnt get it
aslo replied to your pm about bonny box and ecu..
details on the lock up?
posted October 22, 2007 07:16 PM
also might be interested in steering damper...need one if i plan on doing lsr next yr....
zx12mark
posted October 22, 2007 07:32 PM
p.m.sent to you.
NOS1290
posted October 23, 2007 01:48 AM
KZ Scott,
Lockup is an MTC single stage. After I got it set right, I went from replacing a clutch every three passes, to leaving it there for the season. It comes with three spring sets and lots of weights and spacers, but I would provide stack hight and set up baseline that works as a starting point. $350 delivered. Muzzy pump is $75 delivered. Steering damper is a Scotts and comes with an install kit for ZX12. Pain to install but works very well when finished. I can email you photos of any of this stuff if you request by PM. Cheers.
woppi
posted October 23, 2007 07:27 AM
pm sent
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
posted October 23, 2007 08:25 AM
about to pm. i want some parts!
zxmoose
in search of next kill
posted October 23, 2007 08:39 AM
PM SENT
rquinn
posted October 23, 2007 01:42 PM
NOS1290 Cash in hand for rods and fuel pump give me a call @ 601 392-9593 or pm me your number
RON QUINN
NOS1290
posted October 23, 2007 04:37 PM
I'm trying to keep up with the PMs. Thanks for helping me out. Let me know if you think I forgot your request. I'm getting buried with mail
Tom.
say-what-u-want
posted October 23, 2007 04:51 PM
Tom p.m sent (Ron Quinn is good people)
posted October 23, 2007 04:54 PM
did you get the pics for me? s_u_fire....
thx!
NOS1290
posted October 23, 2007 05:35 PM
KZ Scott,
Thanks for reminding me. Photos of lockup sent to your email. Lockup includes the outer plate, spacer, shift rod spacer, extended puller, puller bearing, and the modified clutch cover. The clutch cover has a pressed in throw out bearing seen in photos. $350 total. Includes weights, spacers, SHC screws and instructions. Also includes 3 spring sets. Stock, heavy and heavier. Although the lockup only needs stock if its set up correctly.
Tom Peterson
posted October 23, 2007 05:43 PM
emailed back, pics didnt work. i want it, but i want to see it before i paypal you
NOS1290
posted October 23, 2007 05:49 PM
Sorry. Resent.
All times are America/Va [ This thread is 7 pages long: 1  2  3  4  5  6  7     Next» ] < Previous Thread     Next Thread >
0.37654685974121 seconds processing time
