BIKELAND > FORUMS > CLASSIFIEDS > Thread: BEAR ZX14R UP FOR SALE NEW TOPIC POST REPLY
BEAR
posted June 30, 2002 12:15 AM
We want to start a new project but ,I have to get Rid of my Baby first.So here goes .We have spent over $45000.00 on this bike and you can ad it up
http://www.dragbike.com/news/06-02/rr_9.htm
http://classifieds.internetvisionary.com/default.asp?action=addetail&adid=19340
Paint job --------------------------------------------- Phantom Grafix
Titanium front forks --------------------------- Bear Engineering
Titanium front and rear Axel------------------ Bear Engineering
Titanium plated Stainless steel bolt kit-- Bear Engineering
Carbon fibre print Engine Covers------------- Bear Engineering
Carbon Fibre print front Discs---------------- Bear Engineering
Aircraft Clocks(speedo/compass rpm/alt) Bear Engineering
Titanium plated rear Disc----------------------- Bear Engineering
Polished Lip and sprayed wheels------------ Bear Engineering
Grenade Valve caps------------------------------ Hong Kong
Hugger and UndertaiI----------------------------- FMDS
4" extended and braced swing arm-------- Bear Engineering
Xenon Head Lights-------------------------------- Bear Engineering
Big bore Front callipers-------------------------- Bear Engineering
Anodized bolt covers------------------------------ Bear Engineering
Rear and Front Custom Indicators---------- Bear Engineering
High rise screen------------------------------------ Ermax
ENGINE
48MM Trottle body's-----------------------------Bear Engineering
48MM Velocity Stacks-------------------------Bear Engineering
87mm JE pistons---------------------------------SBM(Superbike mike)
Carrilo rods------------------------------------------Orient Express
87mm Barrels--------------------------------------SBM
4mm Stroked Crankshaft----------------------Falicon
Timing Advancer----------------------------------Bear Engineering
Powercommander 3 R--------------------------Orient Express
Holeshot Shifter-----------------------------------Orient Express
Titanium MUZZY System-------------------MUZZY
Muzzy Clutch hub--------------------------------Bear Engineering
ZX6 Clutch springs-------------------------------Bear Engineering
High Pressure oil pump------------------------Bear Engineering
Balancer shaft Mod------------------------------Bear Engineering
Ported head ---------------------------------------Bear Engineering
Balanced motor-----------------------------------Bear Engineering
Vacuum on crank case---------------------Bear Engineering
Oil channel Modification------------------------Bear Engineering
K & N Airfilters-------------------------------------Bear Engineering
High pressure fuel regulator-------------------Bear Engineering
OHLIN rear shock--------------------------OHlIN
ACCESSORIES
7.5' Micky Thompson drag tyre---------------Orient express
Tyre warmer----------------------------------------Holeshot SA
GPS Garmin 3------------------------------------Bear Engineering
2x Arai zx7Helmets with spray job-------Phantom Grafix
PERFORMANCE
All times and fig quoted at 1656m above sea level
1/4 Mile time = 8.98 sec
1/4 Mile speed = 257 kph
1Km sprint = 307 kph
Top end run 2.2 km = 341kph
Hp = 232
Torque = 187nm
HP +NOS = 313
COST
Total spent on bike = R 415000.00 ($46111.10)
Resell price = R200000.00 ($20000.00) or any good offer (excluding shipping)
  Ignore this member    Click here to visit BEAR's homepage.
posted July 05, 2002 06:50 AM
Any nibbles on it yet, Bear?
0.35133409500122 seconds processing time
