BIKELAND > FORUMS > CLASSIFIEDS > Thread: TONS OF ZX10r stuff!!!!! and some 14 and misc stuff... must gooo!!! NEW TOPIC POST REPLY
garth285
200+mph 2011 ZX10r
posted August 24, 2007 12:55 PM
Parts for sale
Title:
"04-05 ZX10r front brakes complete"
Description:
"Up for sale is a complete set up for front brakes for a zx10r 04-05. Comes complete with calipers, stock brake lines, master cylinder, and brake lever. The lever is slightly bent but in good usable shape. Asking 150 o.bo."
Title:
"04-05 ZX10r Brake calipers front and rear"
Description:
"Have for sale a set of calipers with no lines front and back for a 04-05 zx10r, Im sure the front will bolt right up to a 06-07 as well they are just different color. Asking 40 for each one o.b.o."
Title:
"Kawasaki Racing Exhaust camshaft"
Description:
"I bought this cam to do some expirementing with and I wound up using a different camshaft so I have this one with only about 40 miles on it for sale. In great condition and flawless. Asking $75 o.bo."
Title:
"Muzzy 10 ounce nitrous bottle with valve"
Description:
"This is the bottle muzzy provides with their nitrous kit but I wound up going with a bigger bottle. Has some scratches on it but works fine. Missing the lil 3,000 psi pressure blow off part but that is an inexpensive part. Looking to get $50 o.b.o."
Title:
"Kawasaki ZX10r Stock intake camshaft"
Description:
"I have a stock intake camshaft for a zx10r 04-07 will fit. Had roughly 8,000 miles on it when replaced. Looking to sell for $75."
Title:
"Left hand passenger peg"
Descirption:
"Here is a Left passenger peg for a 04-05 ZX10r in great shape with minor nicks barely anything to look at on it. Perfect condition looking for $30 o.b.o."
Title:
"Stock heel gaurds 04-05"
Description:
"For sale are stock heel gaurds for 04-05 zx10r, in good condition just needs to be cleaned up. Looking for $20 bux"
Title:
"CR250 Rear brake master cylinder"
Description:
"I got this off a CR250/450 to try and replace the zx10s since this has a internal resivor. IT is a pretty neat little master cylinder...... It would be great for someone who doesn't use the rear brake often enough to need full 100% stopping power, since it was designed for a dirtbike it doesn't have as much force as a zx10's master. Looking for $50 for it."
Title:
"Sebimoto Carbon fiber Frame Covers"
Descrition:
"BRAND NEW, NEVER INSTALLED are some 04-05 ZX10r sebimoto carbon fiber frame covers. They go form the neck to the bottom of the frame and are supposed to be glued/epoxied on. Retail for $205 Will sell for $175. ~~~BRAND NEW~~~"
Title:
"ZX-14 Rear Caliper and Caliper bracket"
Descitption:
" For sale is a rear brake caliper and bracket for a zx14r. The bike was laid down and had skid on the right side so ground down a little tab as you can see in the picture. Asking $50 o.b.o."
Title:
"ZX10r 04-05 CARBON FIBER belly pan"
Description:
"Carbon fiber belly pan with minor scuffs on the very bottom, piece is in excellent shape and looks amazing. Mounts up to stock position and is 1 lbs lighter than stock. Will sell for $250."
Title:
"ZX10r 04-05 Stock swingarm cut and re-welded extended 8" "
Description:
"Well I bought this arm off a member on psychobikes well actually traded him the arm for a nitrous kit but its a stock arm cut and re-welded 8" straight as an arrow and looks pretty nice.... does have some small scuffs near the back left adjuster area and it did have a small hit when the bike it was on went down and the pegs bent in and hit the arm.... you can see it in the pics.....looking to get $500 for it with the arm chain and brake line. its a HEL line and the chain is a brand new DID ERV3 520 chain."
http://i7.photobucket.com/albums/y251/garth285/DSCF0223.jpg
http://i7.photobucket.com/albums/y251/garth285/DSCF0224.jpg
http://i7.photobucket.com/albums/y251/garth285/DSCF0225.jpg
http://i7.photobucket.com/albums/y251/garth285/DSCF0226.jpg
http://i7.photobucket.com/albums/y251/garth285/DSCF0227.jpg
http://i7.photobucket.com/albums/y251/garth285/DSCF0228.jpg
http://i7.photobucket.com/albums/y251/garth285/DSCF0229.jpg
http://i7.photobucket.com/albums/y251/garth285/DSCF0230.jpg
hit me up on AIM at garth285 or MSN at garth285@hotmail.com and you can use that for email as well.
  Ignore this member    Click here to visit garth285's homepage.
garth285
200+mph 2011 ZX10r
posted August 26, 2007 09:55 AM
belly pan, side covers and front and rear brakes with out master or lines are going.... still have the rest available.
garth285
200+mph 2011 ZX10r
posted August 28, 2007 01:58 PM
belly pan, side covers and front and rear brakes without master is all gone..... still have rest of parts tho.
0.29976511001587 seconds processing time
