BIKELAND > FORUMS > CLASSIFIEDS > Thread: sprockets for zx12, efir zx14, frame sliders zx14 NEW TOPIC POST REPLY
mrsantafe
posted May 05, 2007 08:48 AM
For sale various sprockets for the zx12
1. titan tough sprocket specialties 44 tooth rear $55 shipped
2. 2 aluminum rear sprockets 47 tooth $40.00 shipped
3. stock sprockets 18-46 cheap make offer
efir for zx14 retails $334.95 from schnitz racing $175 shipped
frame sliders zx14 bolt on to the engine mounts $20 plus shipping
Ignition Retard Unit, Kawasaki ZX-14 - Schnitz
2006-2007
The EFIR-ZX14-06 Retard Module allows the user to progressively retard the ignition timing on the 06-07 ZX-14 with a 12 volt signal. This is a Must for Bikes with Nitrous or Turbos
The EFIR-ZX14-06 also has a timing advance feature that can be used when running the bike without nitrous. This timing advance is applied progressive between 5,000 and 6,000 RPM. Stock timing is used below this rpm to prevent detonation. By advancing the engine at higher rpm, a horsepower increase of as much as 2% can be seen.
This unit plugs right into the factory wiring harness, and is 12 volt activated. Hook it right up to your nitrous solenoids or a pressure switch on your turbo bike, and retard the timing to save your engine.
It is programmable with dipswitches from 0-16 degrees of timing retard, and also has dipswitches to adjust the built time from .250 to 4 seconds.
EFIR's are easy to wire, but you have to wire them correctly. If not wired correctly the bike won't start, or will shut off when it's activated, so read first then wire!
lietoome
posted May 05, 2007 11:04 AM
what do the framesliders look like? If they are black and low-key(no bling)... I'd like them.
lietoome
posted May 09, 2007 04:01 PM
I'd like to buy the framesliders.
lietoome
posted May 10, 2007 11:14 AM
mrsantafe
posted May 10, 2007 01:26 PM
1 48 tooth sprocket, 2 47 tooth sprockets, 1 44 tooth titan tough sprocket
$25.00 each plus shipping.
mrsantafe
posted May 15, 2007 11:04 AM
bump
0.22956204414368 seconds processing time
