BIKELAND > FORUMS > CLASSIFIEDS > Thread: Schnitz Electronics Progressive Nitrous Controller NEW TOPIC POST REPLY
jscarb2
J&S RACING & PERFORMANCE
posted September 02, 2006 01:16 PM
used 1 season set in my shop for a year or so now, one of the dials is missing if i find it it is included. you can still work it perfect.
USED PAID $500 TAKE THE FIRST $350
Schnitz Electronics Progressive Nitrous Controller, 5 Dial - Schnitz Proven for 6 years!!
This is the same controller used by thousands of pro racers and pro street riders for the last 10 years!
The Schnitz Progressive Nitrous Controller utilizes a digital micro-controller for precise timing and control over the injection of nitrous oxide. The rate of nitrous injection is programmable for beginning and final power percentages. The unit also contains a built in digital delay timer alllowing precise control of the starting time of the nitrous injection. An advanced feature is the ability to select the pulse frequency that the nitrous and fuel solenoid operate at. Also, a +12 volt output is available for activating an ignition retard unit or relay. The output is controlled by a digital timer. The timer starts when the unit is activated.
Adjustable in 1% increments 20-100%.
Built in timers for the Progressive, and an additional timer that can control another stage of NOS.
No diodes, or relays needed, just five wires to hook-up.
Adjustable pulse frequency from 20 to 40.
Used by the fastest four cylinder cars and bikes in the country.
The PNC-101 comes with the wiring harness, but they are also available separately.
NOTE: The timer system in this unit will automatically reset 20 seconds after being activated. If the activation power is removed and then re-activated, the Progressive Nitrous Unit will continue from the point where activation was halted. If you get out of the throttle and get back into it, you pick up at the point where you left off at.
Item No. Description Amount Qty.
PNC-101 Schnitz Progressive Nitrous Controller $499.95
jscarb2
posted September 07, 2006 08:14 AM
still for sale
BlackMagic14
posted October 06, 2006 03:57 PM
275 shipped??
jscarb2
posted October 06, 2006 04:05 PM
sorry been sold!
0.22271394729614 seconds processing time
