BIKELAND > FORUMS > CLASSIFIEDS > Thread: ZX-11 Garage Sale NEW TOPIC POST REPLY
posted April 21, 2002 09:53 PM
ZX-11 Garage Sale
I'm selling my 1993 ZX-11 Bonneville bike and all related parts. The engine is currently out of the "rolling" chassis. The chassis has 1000 miles on it, all of this is straight line at Bonneville over 6 years. All stock electrical and lighting is in place.
The engine and parts are as follows:
One assembled bottom end with +3mm lightened and polished crank and falicon "knife" rods. Crank and rods fresh magnaflux OK. Two professionally ported cylinder heads, need freshening, new stainless valves, new stock valves, new valve springs, Muzzy X3 cams. Two complete transmissions, and clutches. Enough to build two engines except for 1 crank and rods. A second set of cases is "used once" with repairable but damaged end thrust surface. 4 sets of 77mm pistons, two sets new, two used but very good. 4 cylinder blocks plus many extra sleeves.
One set 41mm flat slides, One Dyna 2000.
The chassis is modified to accept the flat slides and a very effective fiberglass airbox that encloses the 41's for correct ram air.
There are two complete sets of burgundy bodywork, one set NEW including tank and never mounted. One set used with numbers and stickers. The race set has the turn signal "pods" professionally removed giving smooth sides, the tank is sectioned to be approx. 4 inches lower than stock, very slick looking. Also included are two sets (one set mounted) of Metzeler MEZ-1s
(Never on pavement). Also, Muzzy exhaust and stock exhausts, Corbin seat, stock seat, stock carbs, and special zero gravity windshields. This bike with these parts went 199.44 mph in 1999, held records from 192 to 196 mph. Freshen the head, put it together right and you've got a 180+ hp 1140 that will run 200 mph on the street. $6000 takes it all, I'll pay the shipping.
Pictures on request. Email dmeyer@bendnet.com
KawRider
posted May 19, 2002 06:46 AM
Wheels/MEZ1 Tires
Doug,
I am possibly interested in the Wheels/Tires. Do you think they could be mounted on my 85 Kaw turbo, after a bit of modification? Also a pic would be great!
Thanks!
timmy_larsen@yahoo.com
Tim
Black ZX-14
frEEk
posted May 19, 2002 10:04 AM
wow, seems like a steal to me!
posted May 20, 2002 09:19 AM
I'm not splitting this up. It's a complete bike with spare engine and body parts.
Doug
0.23892498016357 seconds processing time
