BIKELAND > FORUMS > CLASSIFIEDS > Thread: 1270 block and pistons NEW TOPIC POST REPLY
lonniemac
posted June 18, 2004 03:10 PM
i have a 1270 block and pistons for sale . kit is muzzy set up. i can provide new rings clips and pins and also gaskets to make a complete bolt on kit. the kit is used with about 3000 miles on it. i will stand behind the kit 100% to be in excellent shape. the owner wants to go bigger. of course its a zx-12 block.
ninja12
posted June 18, 2004 05:00 PM
how much?
wezze93
posted June 18, 2004 08:57 PM
what hp did it make
  Ignore this member    Click here to send wezze93 an AIM message.
lonniemac
posted June 19, 2004 05:45 AM
there were other things to contribute to this but the motor had no other work other than cams and degreed properly. it made over 200 hp with the hindle pipe and 195 with a muzzy. before you ask the muzzy pipe was faster on the ground. the midrange was better than hindle. you dont spend much time on the road with the throttle pinned to show how much hp.
blubyu
posted June 22, 2004 08:03 AM
Motor
Lonnie,
Did you sell that 1270 kit? What were you asking for it? Send me a pm
Run whatcha brung
Tow whatcha blow
Hells Dark Lord
living life, and loving it.
posted June 27, 2004 06:21 PM
do you still have it? and how much if you do?
bossman12r
posted July 17, 2004 07:57 PM
Yes do you have it still?
gen 4 zx10 is fast
0.22380900382996 seconds processing time
