BIKELAND > FORUMS > HAYABUSA-ZONE.com > Thread: Vance & Hines Motorsports releases New Exhaust and Air Filters for 2008 Hayabusa NEW TOPIC NEW POLL POST REPLY
posted December 13, 2007 07:05 AM        Edited By: frEEk on 17 Dec 2007 12:51
This release comes our way from the Race Shop at Vance & Hines where the crew's been hard at work getting more power out of the '08 'Busa.
New from V&H is the Hayabusa Indy Series Exhaust Kit for 350+ Horsepower Suzuki Pro Stock Motorcycles, as well as their new DNA High Performance Air Filter.
Details below...
Vance & Hines Motorsports - Indy Series Exhaust Kit for 350+ HP Suzuki Pro Stock Motorcycles
A new development from the Race Shop - "The Indy Series Exhaust" - FOR RACING USE ONLY.
Supplied in "kit form" to allow adaptable fitment on most Vance & Hines Motorsports, Trac, PMFR and Kosman frames.
• Designed exclusively for drag race applications, this 4:1 exhaust is the ultimate design for peak power.
• Quality, lightweight stainless steel construction.
• Tapered head pipes, full merge 4:1 collector and tapered intermediate pipe for maximum performance.
• Slip fit collector joints with "dual swivel end retention springs".
• Includes aluminum CNC machined "D" port spigots
• Tuned length megaphone.
• O2 sensor bung in rear collector for wideband air/fuel ratio monitoring.
• Weighs only 8 pounds.
• Includes spring puller tool.
*Requires some welding and drilling. Intermediate pipe angle, spring tab locations, EGT placement will vary with fairing design, clutch cover design, battery location, etc.
1) Weld intermediate pipe to collector
2) Weld spring tabs on collector and lower head pipes
3) Weld EGT fittings on head pipes and drill sensor hole
4) Weld O2 bung on intermediate pipe and drill sensor hole
Indy Series Exhaust: P/N 73-102-1
Suggested Retail $1,250.00
Weight for shipping - 15lb's
A new development from the Race Shop - "DNA High Performance Air Filter" - For Racing and Street Use.
Vance & Hines Motorsports announces New DNA High Performance Air Filter for the 2008 Suzuki GSXR 1300 HAYABUSA.
• This new DNA performance air filter is designed for race & road use and features DNA'S Full Contour Design.
• This drop in stock replacement air filter has a 17% larger filter area than the stock filter and has sufficient flow for 225 + HP engines.
• The filtering material follows precisely the airbox shape and the complete area is used to achieve a very high flow rate (36% more air flow).
• The DNA High performance air filter is a high quality next generation multi layer cotton gauze oil impregnated air filter.
• The filter media is made of 4 layers of high quality nafta surgical cotton gauze, sandwiched between two layers of epoxy coated Marine grade aluminum wire mesh and designed
to last a lifetime.
• The 4 layers of cotton and the two layers of wire mesh are pleated by state of art electronically controlled pleating machines to assure a very high quality of the final filtration media.
• The result of this special design is a filtration media that has very high flow rates, low restriction, superior dust holding capability and lasts a lifetime.
DNA High Performance Air Filter P/N #6-2004
Suggested Retail Price $114.20
Available to ship in December 2007
For more information, contact:
1211 Northfield Drive
Brownsburg, IN 46112
Phone: (317) 852-9057
sales@vhmotorsports.com
Source: BIkeland.org
LandspeedLarry
posted December 13, 2007 08:02 AM
Your pictures show the proper bolt-on sidewinder for the 2008 Hayabusa. The written description, however, is for the Pro/Stock pipe for a GS air-cooled engine. The Hayabusa pipe is $1185. and weighs 10 lbs.
Home of the World's Fastest Naturally Aspirated motorcycles.
TRNorBRN6001
posted December 13, 2007 08:49 AM
Does the pic of the Filters match, if so then its different than the older busa airbox.
Cool stuff, might have to go to the Darkside and run a big N/A Motor.
TFA 200MPH CLUB MEMBER!
LandspeedLarry
posted December 13, 2007 10:11 AM
Haven't seen a new Busa yet but the air filter looks similar to the GSXR 1000 which also uses dual injectors so I would think that is the right filter pictured. Do I get credit for another post, since my avatar got carried over? lol
TRNorBRN6001
posted December 13, 2007 12:26 PM
It'll be interesting to see the airbox configuration on the new Busa. Can't wait for a
chance to check one out a little.
posted December 15, 2007 03:54 PM
I was wondering why it said welding required and such.
0.24564981460571 seconds processing time
