BIKELAND > FORUMS > ZX-14.com > Thread: Clutch Lever change problem NEW TOPIC NEW POLL POST REPLY
Kennyz
posted December 29, 2016 02:14 PM
I was going to change the levers on my 2015 ZX14R . The new clutch lever would not fit , I put the original clutch lever back on, now the clutch will not disengage. I put it in first and it starts creeping. The lever only pull partially in and stops solid. The small rod is seated in the lever OK.
0.25481295585632 seconds processing time
