BIKELAND > FORUMS > ZX-14.com > Thread: Brake drag help NEW TOPIC NEW POLL POST REPLY
JGIG73
posted October 14, 2015 06:55 AM
Brake drag help
Wanted to know if you guys are getting a small amount of drag on your front and rear brakes. Yesterday I did a front caliper cleaning (without removing the pistons and seals) scrubbed everything down with Palmolive dish soap worked the pistons in and out of the calipers and re assembled. With the front wheel off the ground the tire spins however I can hear a very quiet amount of drag and it slows the wheel down. Its not a drastic slow down but its evident. Took the bike to work today and braking was very good, with a linear feeling. Drove 20 miles and parked the bike, immediately I touched both front rotors and they where only slighty warm. The rear rotor however was hot. To the point where I couldnt keep my hand on it. The rear rotor isnt discolored or warped, but its getting hot from a small amount of drag. Could this be a sign of the seals needing to be replaced as they are not allowing the pistons to fully retract into the calipers, or is it normal to have a fair bit of drag on the front and back. My fluid levels are not over filled in the reservoirs.
INTIMIDA2OR
RED rider!
posted October 14, 2015 08:45 AM
Your front brakes sound pretty normal to me. The rear is definitely not right at all if it is getting hot without use.
The caliper could have buildup around the seals causing it to stick and or there could be air in the system too. Also an alignment issue could do it. Like if the rear wheel not being aligned with the marks on the swingarm.
'06 Passion Red ZX-14
*Lee*
JGIG73
posted October 14, 2015 02:51 PM
Rear wheel is aligned with the swingarm markings, resevoires are not overfilled. Jjust got done ripping apart the rear caliper and scrubbing it all out, was pretty filthy and one of the pistons was stuck. They are both moving freely after the cleaning. Will test tomorrow morning. Thanks!
0.31256318092346 seconds processing time
