BIKELAND > FORUMS > ZX-14.com > Thread: lose cam chain tensioner NEW TOPIC NEW POLL POST REPLY
losttribe9
losttribe9
posted February 18, 2015 01:15 AM
Will a lose cam chain tensioner cause your bike to shut off at highway speeds
Ndacurv
zx12mark
posted February 19, 2015 05:06 PM
I would`nt think so. How much noise is the cam chain making.I would think you have an electronic problem.Are the battery terminals good and tight.You have a zx14? year? .Checked for stored fault codes in the ecu...?
zixxer14
Damn that was Quick
posted February 20, 2015 06:22 AM
If it's loose enough to jump teeth maybe, valve timing could change causing bent valves or bad running. If it is bad changing to the Ape manual adjuster would be my recommendation, I've been using one for years & only adjusted it once since installing it.
INTIMIDA2OR
RED rider!
posted February 23, 2015 12:04 AM
Depends on if the bike starts back up ok. If it doesn't then the cams jumped time and now it's engine teardown time.
if it starts back up and runs fine then i'd rule out the CCT causing the shutoff problem. Is the motor making rattling noises?
I'd change the spark plugs and see if the problem goes away.
'06 Passion Red ZX-14
*Lee*
0.24969696998596 seconds processing time
