BIKELAND > FORUMS > ZX-14.com > Thread: 07 not right NEW TOPIC NEW POLL POST REPLY
big nickel 14
posted July 30, 2014 05:30 PM
07 not right
hey guys, its been awhile since i've been on, even though i check daily.this has been a thorn in my side. bike starts like a champ,next time runs like a diesel. have to hold her 2000rpm till she;s warm, then she's ok. no codes flys out, pc3, checked everything aside from changing throttle bodies or ecu. anybody! thanks in advance big nickel
Ozonkiller
posted July 31, 2014 02:54 AM
Ditch the PC and see if the problem goes away. If so, probably bad ground
Tom
big nickel 14
posted July 31, 2014 12:25 PM
thanks tom,but been there, never made a difference, cold start only, sometimes it fires up, or it starts to bog and eventually stalls. will run and start fine all day no problem
SixSixoh6
posted August 11, 2014 08:47 PM
Being as it just seems to happen intermittent, notice a running issue with changes in humidity or wetness outside? The electrical gremlins like to populate there
big nickel 14
posted August 12, 2014 02:33 AM
thanks for the reply six, but she's garage stored,temp or conditions never made a difference, gonna try swapping the throttle bodies when i can find a set. just been living with it, but it is getting on my nerves lately
0.31016802787781 seconds processing time
