BIKELAND > FORUMS > ZX-14.com > Thread: Stroker clearance question NEW TOPIC NEW POLL POST REPLY
Ozonkiller
posted July 22, 2014 02:50 PM
What is the minimum clearance that you guys are running at BDC between the piston and the primary and balancer gears on a 4mm stroker?
Tom
06 ZX14
06redzx14
posted July 25, 2014 06:28 PM
Which pistons are you using? Sorry for the thread heist
Ozonkiller
posted July 25, 2014 08:13 PM
Wossner 86mm
posted July 26, 2014 10:23 AM
40 thou?
06redzx14
posted July 26, 2014 07:20 PM
Short rods or do they make a stroker piston?
Ozonkiller
posted July 26, 2014 09:08 PM
Already have the short rods. Carillos.
I ran 40 thou on the stock bore set up before with no problems. I was just wondering what clearances other guys who are running strokers are using.
I was talking to a guy running a big block 555 cu in. Chebby who runs .025 in. It makes sense since we're talking compression of the rod and clearances right on the centerline.
0.21244096755981 seconds processing time
