BIKELAND > FORUMS > ZX-14.com > Thread: 2012 - ZX14R 6th Gear problems NEW TOPIC NEW POLL POST REPLY
FAST Z14
posted July 21, 2014 09:36 PM
Taking my 14R in today to have the G/box checked , bike does not want to shift into 6th gear, all the other gears are fine. I know of another 14R that had the same problem, anybody else had this problem
FOLY HUCK
Ninjavin
posted July 22, 2014 03:08 AM
You got the extended warranty?
FAST Z14
posted July 22, 2014 04:44 AM
No out of warranty, wouldn't have matter anyway ECU has been flashed, shifter,pipe etc.
FOLY HUCK
Seno
BANNED FOR LIFE!
posted July 23, 2014 03:31 AM
Don't you remember when bikes only had 5 speeds?? 6th is over rated
INTIMIDA2OR
RED rider!
posted August 04, 2014 04:45 PM
Sounds like the shift star is damaged or the shift drum is damaged somehow.
Keep us updated on what is found.
'06 Passion Red ZX-14
*Lee*
FAST Z14
posted August 04, 2014 09:30 PM
The sir clip came loose on the 6th gear selector shaft - fork bent, that is what I am told, waiting for parts from Kawa, should be fixed month end. Repair shop is going to under cut the gears as well. Told them to remove the complete Bazzaz Tune Unit & shifter , the shifter has been messing around for quite some time now in the higher rev range from 9000 rpms to 12000rpms. Dont need the Bazzaz anyway have the flashed ECU - Woolich
FOLY HUCK
INTIMIDA2OR
RED rider!
posted August 06, 2014 12:02 PM
Sounds like the shift star is damaged or the shift drum is damaged somehowive hd
Wow I didn't expect to hear a circlip failed but they can and obviously this one did.
Truly a rare type of failure. I have almost 140,000 miles on my 06 and the only failure Ive had are the cam chain tensioner and batteries that eventually die lol.
*Lee*
0.44112992286682 seconds processing time
