BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 no spark! NEED HELP!! NEW TOPIC NEW POLL POST REPLY
Claming72
Claming72
posted May 15, 2014 07:33 PM
About 9-10 months ago I let my brother barrow my 06 zx14 with 44k miles(was running strong). He claimed to be riding down the road and it slowly lost power and wouldn't Turn over or prime fuel pump. Shortly after I found several shorts in harness and replaced it with a used but newish one and the I moved and it got shored in back of my garage until now. I replaced battery, ecu, relay assembly, and start/stop switch. After a short in start/stop switch wire it primes fuel pump and turns over but no spark. I took it to 2 of the largest cycle shops in town and both wanted a minimum of 8hrs at $90 to work on it. Does anyone have ANYTHING THAT CAN HELP?!?! Does new ecu need flash? Crank or cam sensor?
INTIMIDA2OR
RED rider!
posted May 17, 2014 10:49 PM
Is the fi error flashing on the dash?
is there power at all the fuses ?
'06 Passion Red ZX-14
*Lee*
posted May 18, 2014 06:23 AM
You've replaced the entire wiring harness, ecu, relay and battery? Are there no other shops nearby?
Claming72
Claming72
posted May 18, 2014 10:19 AM
No f1 light. I got drunk last night and pulled engine out and started checking wires and the "coil wire loom" that sits on valve covers had a short. What do you think causes all of these shorts??
Oz Booster
posted May 18, 2014 01:12 PM
what do you mean by short ? how are you testing
posted May 18, 2014 03:17 PM
You pulled the engine out?
How bout a few pics of that.
1badzx12r
posted May 18, 2014 06:28 PM
I have to say it be booze..
INTIMIDA2OR
RED rider!
posted May 18, 2014 07:59 PM
+1
*Lee*
posted May 18, 2014 08:23 PM
posted May 19, 2014 04:49 PM
So what's the verdict?
0.23935890197754 seconds processing time
