BIKELAND > FORUMS > ZX-14.com > Thread: Spider kit NEW TOPIC NEW POLL POST REPLY
bigwil
06 zx 14 turbo stage 3
posted April 06, 2014 03:43 PM
Spider kit
Ok getting ready to put a shot on the 14r and whant to see witch one guys lk and why the mps kit uses 4 jets right at the tubes runs 405 no bottle now the dyno tune uses only one jet at the solenoid making a easy to change and goes for 250 no bottle and no starter switch relay price not being a factor witch do you lk and why thanks for input
bigwil// going fast aint easy so turbo it
posted April 08, 2014 06:51 PM
a dynotune, upgraded with a shower head and ss hardlines aimed down the stacks.
cliffrandall
posted April 26, 2014 08:03 AM        Edited By: cliffrandall on 26 Apr 2014 16:10
Here's 250hp & 145ft/lbs with the Muzzy kit. Very simple to install and bulletproof with the PC5 ignition and fuel control. One map for motor - hit the juice and you automatically get your 2nd n2o map, more fuel and less ignition (I run 50/50 pump and C12). Match it up with the Muzzy shifter for a fabulous and inexpensive system..........Watch the video, you can't even hear the juice come on, it's that smooth.
Cliff
http://s1077.photobucket.com/user/cliffrandall/media/CliffRandalls2013MuzzyKawasakiZX-14HTmaking242rwhp_zpsae874c36.mp4.html
BrucerZX14
posted April 27, 2014 06:31 AM
I have the MPS Spider system In my ZX14. All automatic. Completely seamless. I spray off the line at 45% and ramp up to a 40 shot in .8 seconds. Here's a video on my last years final race. Go juice is AWESOME! https://www.youtube.com/watch?v=ZyxDuvXkaqE
RICH CRAFT 1
posted April 28, 2014 01:12 PM
MPS Spider system +1
Red 06 ZX14 RR
cliffrandall
posted April 29, 2014 09:39 AM
Great video Bruce.......Question - does the MPS system allow for additional fuel and ignition retard?
Thanks,
Cliff
BrucerZX14
posted April 29, 2014 07:28 PM        Edited By: BrucerZX14 on 30 Apr 2014 03:28
The MPS system is a dry set up. NOS only. I use a Power Commander V for fuel and an MSD SB6 for timing retard.
cliffrandall
posted May 01, 2014 01:22 PM
Bruce......I add 20pts of fuel up top (I hit my juice in 5th & 6th gear at 10,000rpm) and pull 5 degrees of ignition timing - from my pump map, which adds 2 degrees of ignition over the stock ecu......How about you, what's your map look like?
Cliff
cliffrandall
posted May 02, 2014 06:26 PM
Forgot to mention - 17/38 gearing.
Cliff
BrucerZX14
posted May 02, 2014 08:04 PM
cliff - How much are you spraying? I only have a 40 shot right now but gonna work up to an 80 shot. I hit mine right off the line. Spray 50% on the launch with a .8 sec ramp to 100%. Map is a little richer than what comes with a Brocks pipe map.
cliffrandall
posted May 03, 2014 05:12 AM        Edited By: cliffrandall on 3 May 2014 15:20
Thanks Bruce......I spray 45hp at the rear wheel, on the Champion Cycle dyno - for comparison purposes, SAE smoothed to #5, the lowest HP reading you can get on a dyno. I'd be curious to know what other kits actually spray on a dyno set at an SAE reading........Have you had your's on a heartbreaker? Don't get shook by the high finish F/A reading on the dyno - I asked Dan to kill the juice at 10500, what you're seeing for a split second at 13.5 to 1, is the residual n2o in the airbox after the TB injectors stopped firing fuel. Our best n2o power on C12, was made at 13 to 1 as you can see from the graph. We made about 10 runs on the dyno to get it right.
Cliff
[URL=http://s1077.photobucket.com/user/cliffrandall/media/CliffRandalls2013MuzzyKawasakiZX-14HTChampionCyclebuiltnitrousampmotormaps_zps4ca973b3.png.html][/URL]
bigwil
posted May 03, 2014 12:39 PM
I see the mps spider kit comes whith the swapper switch does any one no if its the dual
bigwil
posted May 04, 2014 07:04 AM
Found my own answer it comes with dual swapper switch horn and starter
debo33
posted May 06, 2014 07:21 PM
what times do u run..does bike spin or wheely...
Lonnie Anthony
  Ignore this member    Click here to visit debo33's homepage.
0.23229813575745 seconds processing time
