BIKELAND > FORUMS > ZX-14.com > Thread: Just ordered a Shorai Battery for my 08 zx14 NEW TOPIC NEW POLL POST REPLY
customizedcreationz
posted December 17, 2013 07:39 AM
I did a little research and it seemed like a good battery from the comments.
Anyone care to input on how theirs is holding up?
Todd
2008 ZX14
www.customizedcreationz.com
SteddyTeddy
posted December 17, 2013 07:55 AM
They work just fine. Only problem some have is starting in cold weather.
customizedcreationz
posted December 17, 2013 08:32 AM
Thats interesting because I say alot of people talk about how good they start in the cold weather? Videos with temp gauges etc.
Hmm...
2008 ZX14
SteddyTeddy
posted December 17, 2013 09:45 AM
Im told you have to cycle them once or twice then all is good. Doesn't usually get that cold here in FL so I haven't had any issues.
customizedcreationz
posted December 17, 2013 11:02 AM
Well I am in Michigan ( though I ll be heading to Florida for Daytona hopefully next year ), so I see cold weather, but I usually don't ride in cold weather, which to me is below 40.
Todd
2008 ZX14
zxrider11
posted December 17, 2013 03:34 PM
Any temps below 40 degrees requires turning the key ignition to ON, and allow the battery to cycle for a minute or two.
I have had mine for about 2 years, and no problems so far.
By swapping out the original battery & battery tray, the weight savings is close to 11 pounds.
2008 ZX14 Atomic Silver
2012 KTM 690 Enduro R
customizedcreationz
posted December 17, 2013 03:44 PM
That is interesting, maybe I just didn't research enough or missed that part of the information. Thank both of you for the information on that. Hopefully I ll have my battery soon and can get my bike running again.... though there is 6 inches of snow on the ground, I won't be do anything except start it up in my shop.
Todd
2008 ZX14
WRECKSHOP
posted December 18, 2013 09:50 AM
I bought 2 Shoria Batteries a year ago now both are toast. They suck. I also bought their battery charger too. Waste of money.
SteddyTeddy
posted December 18, 2013 11:04 AM
Going on a year or so with mine. No problems. I plug it into the charger when not in use for a week or more. I've got the little LFX14A2 turning my high compression 1300 motor.
posted December 18, 2013 08:41 PM
I bought alien motion battery this past year. I'm very pleased with battery
WARBIRD
posted December 19, 2013 09:32 AM        Edited By: WARBIRD on 19 Dec 2013 17:32
I have Balistic battery's and all is good. Keep ours on the charger too when not in use. When really cold you might have to try and start the bike a couple times but every time you turn on the key or hit the starter button, then turn it off it generates it's own heat and the resistance goes down. This explains it pretty good......
I'd Rather Be Roadracing.
tuusinii
posted December 19, 2013 11:51 AM        Edited By: tuusinii on 19 Dec 2013 19:52
You shouldn't keep the li-on batteries on trickle charger. Keeping them at high voltage will only shorten their lifetime. And you should check your charging systems voltage - too high and you will ruin your battery. And most important thing is not to let them drain empty.
WARBIRD
posted December 20, 2013 10:19 AM
Not a trickle charger......their charger has a storage function as well as a balance function. I find that mine is rarely even on ( working )
http://www.ballisticparts.com/products/Charger/chargerBalance.php
0.23371195793152 seconds processing time
