BIKELAND > FORUMS > ZX-14.com > Thread: Clutch issue NEW TOPIC NEW POLL POST REPLY
lilryan
posted December 06, 2013 02:05 PM
Clutch issue
So I was installing my cycle logic lockup today and ran into a problem. After I took the springs off the pressure plate came off so i put it back on. It did not sit flush against the clutch pack so i called Brocks and they said to just slowly tighten everything and it should pull itself back together. I did this and the pressure plate eventually snapped into place against the clutch pack. Now i dont have any pressure on my clutch lever. Everything looks normal. i can hold the pressure plate by hand and the squeeze the clutch lever and watch it push my hand out. But there is never any pressure on the clutch lever even after it is all tightened up. I dont know what happened but something is wrong. Any help would be much appreciated.
Ryan
2006 zx14 - Brocks Black Streetmeg / BMC filter / Muzzys AIR delete / PCV / Guhl Motors ECU / PUIG DB 190hp, 112tq
0.24557089805603 seconds processing time
