BIKELAND > FORUMS > ZX-14.com > Thread: Vortex vs Sato Rearsets NEW TOPIC NEW POLL POST REPLY
epd345
posted November 16, 2013 07:51 AM
I am considering getting some aftermarket rear sets for a winter upgrade. I had some Sato's on my 2007 and I loved them. I used them in the lowest position for the most comfort and they cleared my Yosh Exhaust with no problem. I guess I have two questions. Will the Vortex rear sets go as low as the Sato's? And will these rear set come into contact with the Brock's CT Meg which comes out right under the right peg.
Rook
posted November 16, 2013 10:12 PM
can't comment on the clearance with the CT you have on there but can tell you that the Vortex will be just a bit heavier than Satos. If you dremmel out the heal guards, the weight will be about the same.
Vortex looks to have about he greatest range of adjustability. I have them on my 14 and Satos on my busa
Vortex looks a lot better for a big bike like the 14 IMHO. They adjust a bit lower than the stock height.
BTW...OEM footpegs and brackets are lighter than any rearsets. If you want lightweight and stock height just get a set of aftermarket aluminum footpegs and save $$$ too.
[URL=http://s461.photobucket.com/user/Rookzx/media/2008%20ZX-14/Body%20and%20Exterior%20Parts/controls/Vortex%20rearsets/Vtxbrakerear.jpg.html][/URL]
epd345
posted November 17, 2013 11:02 AM
Thanks Rook, looks like in that picture you really couldn't put those in a lower position. looks like the attachment for the brake lever would come into contact with exhaust. For me I would want to run those things in the lowest position for comfort.
joseph702
posted November 17, 2013 05:22 PM
The sato clear the ct exhoust. I have them abd love them . I fliped them for reverse shift
epd345
posted November 19, 2013 03:20 PM
Joseph Im inquiring about the Ct Meg, the shortie. Im thinking the Sato's would fit but not in a low position.
[URL=http://s169.photobucket.com/user/Fathertime345/media/DSC03825.jpg.html][/URL]
Lsantana954
posted November 30, 2013 05:31 PM
I had clearance issues with my CT meg when i installed my Driven rear sets, you MIGHT have similar issues. I ended up having to completely remove the belly fairing, modified the muffler bracket 3/8 of and inch lower i also removed the upper spring and the grind down the spring tab from the muffler side. Even after all that i noticed that if i pressed on the rear brake hard enough if would still hit the muffler and then i realized that my brake pads were pretty worn. Swapped out the rear pads and the pedal no longer hits.
I also was looking at the satos but decided to go with the driven cause their rear sets offers more adjustability options
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
epd345
posted December 01, 2013 01:40 PM
Thanks for the info Santana. Sounds like Im going to stick with the oberon pegs that I have on there.
0.26209902763367 seconds processing time
