BIKELAND > FORUMS > ZX-14.com > Thread: rear wheel hop on hard brake NEW TOPIC NEW POLL POST REPLY
oldtimer
posted October 26, 2013 09:37 PM
any recommended adjustment on rear shock that could reduce rear wheel hop on hard brake condition 2007 zx14 - thanks
cs
trganey
posted October 27, 2013 03:05 AM        Edited By: trganey on 27 Oct 2013 11:07
Not that I know anything about suspension but we have ours adjusted for easy compression and slow rebound. It's set up for drag racing but it's street ridden too and we don't see the problem you describe.
BTW: Like the screen name! Doubt that your as old as me but there are several of us old farts that ride the 14's
posted October 27, 2013 04:39 AM
Less rear brake should resolve that issue. That's not a common heard of issue
INTIMIDA2OR
RED rider!
posted October 27, 2013 01:10 PM
+1
'06 Passion Red ZX-14
*Lee*
Lou_ZX12R
One Day at a Time
posted October 27, 2013 02:32 PM
My rear hops under hard breaking or extreme down shifts from high speeds. But It didn't start to do this until my tire got more than halve way worn. I believe once I replace the tires it should resolve most of it. My 12r does the same thing when the tire is worn out more than50%
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
Brock
Sponsor
posted October 29, 2013 01:57 PM
Lou_ZX12R,
Just trying to help here, since hop can cause loss of control in an instant.
All bikes, without slipper style clutches, will hop if you down shift from an inappropriate speed (or excessive RPM) into the wrong gear. It might be advisable for you to enroll into a track day school to improve your form.
Your shock might be worn out? (lack of rebound dampening) But if you have two bikes doing the same thing, it doesn't sound likely to be mechanical.
Brock
Brock’s Performance
  Ignore this member    Click here to visit Brock's homepage.
Lou_ZX12R
One Day at a Time
posted October 29, 2013 02:40 PM
Lou_ZX12R,
Brock
Brock’s Performance
I appreciate the concern, the process in which this happens is well in control. The shock is fine, my setting is a bit more stiff than what most would prefer and this usually happens when the tires are worn more than 50%. I still have the stock tires on, a good set of Pirelli's should fix this.
By the way i love my flash
Lou
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
zixxer14
Damn that was Quick
posted October 29, 2013 06:52 PM
i think Brock is right here, better technique would eliminate this better than new tires. Tire wear is immaterial to locking the rear tire compared to better control of revs & clutching.
0.2451069355011 seconds processing time
